Is it OK to keep the top down in my C5 for long periods of time without damaging the top? I'm thinking like all summer long without putting it up until I'm ready to store it for the winter. I only drive the car to shows and relatively short distances during the driving season in Pennsylvania. Any advice or similar experiences will be greatly appreciated.
Leaving the top down for a long period of time should not damage it. However, I left mine down for 3 days (in my garage), when I put it up there are now some permanent creases on both sides.
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
If you show the car you will have to put up the top at some point. It will have creases in it when you do.
Based on the feedback so far, I'm going to put the top up as soon as I get home tonight. It's been down for two days. Hope I don't have any permanent creases.
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I leave the top up on both of my C5's - occasionally I'll leave it down over night. You can just put the top up and not latch it - just don't drive it that way!
I've owned many convertibles, here's what I've learned FWIW. As you use the car the top will age. If you keep the top up and it's out in the open, the elements will take their toll over time. If you keep it down it will develop creases and while driving the folds rub against each other causing marks. In addition, the up & down process causes some stress and wear. So, if you know for sure you will use it again, soon, with the top down, just leave it down. All other times I'd put it back up. Keep it clean and never store it damp. Use only cleaning and dressing products meant for the convertible top you have. Cloth and vinyl products can be different.
New top is $1500 installed-don't sweat it-I leave mine down almost all the time in the garage. The thing you DO NOT EVER WANT TO DO, is store the top WET.
The previous owner left it down for most of the Summer.
I left my 03 top down all summer each year. It creases, but not permanently. When you put it up and rinse it off and let it dry in the sun, the creases disappear. At least they did on mine. There's only a couple of small creases that appear, one on each side where it folds to the rear of the side windows. The rest stretches tight and never creased.
I live in the happiest place on earth and with our weather, the top has been down for more than a year, without any problems. Used Raggtop and it looks great.
I put mine up most of the time when I get home. Sometimes I don't even latch it. Not sure what the issue is, takes way less than a minute and keeps the inside of the car clean.
I say put it up when you are not using it. There is always humidity, especially in the south at night, and the top absorbs moisture so keeping it folded up can't be good. Even if you think it's dry, it probably has a little moisture in it.
And I think you ought to latch it most of the time as well. Keeps everything taut and may keep pieces from warping.
I think the thing us Vert owners need to worry about more is the back window coming out. I would be interested to know what people think contribute to that. Is it that Verts are just sitting out in the sun, day after day, and that destoys whatever is holding that window in?
