HELP, cleaning custom floormats advise???????????
1. Spray the foam on the floor mat, let it soak for 2 minutes, then use a very stiff carpet brush and scrub the floor mats in all 4 directions for a good 5 minutes. Scrub the embroidery in the direction of the stiching, otherwise, you run the risk of tearing the threads.
2. Spray the floor mat liberally with WATER to rinse out the dirt and cleaner.
3. Then wipe and press a clean white towel into the mat until damp.
4. Air dry.
(If the Woolite doesn't work on the embroidered part, I use a mix of 3 parts water and 1 part Purple Power All Purpose Cleaner... O'Reilly Auto Parts... and scrub the emblem with that. Pretty strong stuff so be sure not to use it full strength. Only 3:1 or 4:1. Rinse thoroughly with water. Towel dry. That will get the emblems clean.)
2. Spray the floor mat liberally with water to rinse out the dirt and cleaner.
4. Air dry.
(if the woolite doesn't work on the embroidered part, i use a mix of 3 parts water and 1 part purple power all purpose cleaner... O'reilly auto parts... And scrub the emblem with that. Pretty strong stuff so be sure not to use it full strength. Only 3:1 or 4:1. Rinse thoroughly with water. Towel dry. That will get the emblems clean.)
