Battery Tender Advice
Old Mar 24, 2010 | 02:44 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Default Battery Tender Advice
I went to start my '01 coupe on Monday, and it would not start. The battery barely turned the motor over. I put a neighboors charger on it last night for about 2 hours and tried and it fired right up. Went out today about 9 am and it fired up again. It appears that the battery is ok, but I don't drive it that much so it sits in the garage covered and waiting. What is a good brand of battery tender I can get to keep it charged when I know it won't be out for a few weeks?
Old Mar 24, 2010 | 02:52 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
I have the Battery Tender Plus and it's worked perfectly for the past few years. Keeps the battery ready to go all winter long.
http://www.autogeek.net/btplus.html
Old Mar 24, 2010 | 03:11 PM
hotwheels57's Avatar
hotwheels57
I've used the BATTERY TENDER PLUS (@ 1.25amp by DELTRON CORP) for several years on all of my OPTIMA batteries.
The latest greatest float charger is from Europe. It's the CTEK, model #US3300 which has dual input ratings @ .8 and 3.3amp for different types of batteries.
Either is safe for full time use during prolonged periods of hibernation. Mine is connected all winter long and anytime the car isn't being driven. They each have lots of electronic safeguards. Just don't drive off w/o disconnecting the charger from the battery.
A nice low amp input puts less heat into a battery (regardless of the battery manufacturer) and will not harm the internals.
Old Mar 24, 2010 | 03:17 PM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
I used the CTEK 3300. It will cycle in and out as needed. Great little charger/monitor. Can be purchased thru the forum. Do a search.
Dave
Old Mar 24, 2010 | 03:35 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Battery Tender Plus I have used one for about 5 years now and never a problem. Great unit.
Old Mar 24, 2010 | 04:02 PM
Darion's Avatar
Darion
Old Mar 24, 2010 | 04:19 PM
Varmit's Avatar
Varmit
St. Jude Donor '08
I have a CTEK 7000, no problems so I'm really happy with it. Bottom line, they are all probably about the same.
Old Mar 24, 2010 | 05:00 PM
killain's Avatar
killain
Oldtimer
I have a battery float charger made by VDC Electrionics, called Batteryminder, plus. But C-tek makes a really good float/charger and Batterytender is another good one. I have a Optima in my Vette, and I bought a charger that is made specifically for Optima and Odyssey batteries. Spiral wound cells.
Old Mar 24, 2010 | 05:12 PM
34RedRage's Avatar
34RedRage
harbor frieght carries a tender for less than 10 bucks. i use them in all my cars, trucks,atv's and toy hauler. they work great...dont pay for a brand name, they all work the same way.....
Old Mar 24, 2010 | 05:33 PM
DeltaBravo's Avatar
DeltaBravo
I got one at Sears for under $20 a while back. It's a 6/12 volt, 1 amp unit with clips and cigarette lighter adapter. Real convenient to plug into the lighter and keep the battery charged up.
Dennis
Old Mar 24, 2010 | 05:44 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Just remember that there is a difference between a battery charger and a battery maintainer. Your old fashioned battery charger can be set to be a trickle charger, meaning that you can send a small constant state charge of about 2vDC. But the problem is it is a constant state charge, and when the battery reaches it's full charge, it continues to send the charge....eventually the battery will start to sulfate the cells and if left long enough - the electrolyte will begin to boil....and evaporate.
A battery maintainer will monitor the state of the battery and will only send current when the charge begins to go down. So if there is a $10 battery charger that does the same thing - buy it. I have used the CTEK and the Battery Tender brands and both do an excellent job.
Old Mar 24, 2010 | 05:50 PM
Oldvetter's Avatar
Oldvetter
I got a Black & Decker one from WalMart for about $18 a few years ago. Had some problem with it and sent it in for warranty, they sent me a Vector charger. Both had a 1 amp or 2 amp switch. Has worked fine since.
Old Mar 24, 2010 | 06:53 PM
arkus's Avatar
arkus
I've used one on a battery from 2002 until now with no problems with a red top optima battery , fires up all the time.
Old Mar 24, 2010 | 06:56 PM
dobewillie's Avatar
dobewillie
Ive used the black and decker from Wally Mart with no problems
Old Mar 24, 2010 | 07:38 PM
rickko's Avatar
rickko
I'm like you, drive my vette about once a week. Now six years after the original AC Delco was installed its getting a little weak if not kept on the Battery Tender. I'm using a Battery Tender Jr. (.75amp instead of the 1.25amp) "Plus" model. Its cheaper and works well since it has a week to keep the battery charged between drives.
My point, if you don't drive much at all you'll save some money buying the Jr. model over the Plus model if you don't need your battery recharged quickly.
..rickko..
Old Mar 24, 2010 | 09:34 PM
Red Vamp's Avatar
Red Vamp
I never could understand what all the fuss was about "battery tenders". For ten years now I've used a fully-automatic Sears with 2 amp trickle charge for winter...never had a problem and she always fires right up after four months in storage. They also do quick charges and jump-start for about $40 on sale.
Old Mar 24, 2010 | 09:49 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
used Battery Tender this winter for first time.....it's still the original 04 battery so I figured why tempt the battery gods .......
Worked great by the way ...
To Battery Tender Advice
Old Mar 24, 2010 | 09:54 PM
MagneticRed1977's Avatar
MagneticRed1977
Anyone know what is causing the discharge?
I had charged mine up a month ago and then yesterday it was dead, dead, dead. When I hooked up the charger the first thing I heard was a loud clicking somewhere in the neighborhood of the radiator. I ended up pulling the cables and then pulled the battery. On my charger it would only take 2 amps for a while and after 5 hrs it was fully charged. I then did a load test and it was fine.
Old Mar 24, 2010 | 11:07 PM
RDKING's Avatar
RDKING
I have been using a Battery Tender since 97 on my Motorcycles and cars and never had a problem. My batteries seem to last longer than other guys I know. I reccommend Battery Tender.
Old Mar 24, 2010 | 11:11 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Ctek 7002 here. Love it!
http://www.shop.jwmotoring.com/categ...?categoryId=43
