Harbor Freight Battery Tender
Old Mar 25, 2010 | 06:40 PM
mag red vette's Avatar
mag red vette
Default Harbor Freight Battery Tender
The Harbor Freight battery tender is much less expensive that the Battery Tender Plus or the CTEK. Although I am a big fan of Harbor Freight, I find some of their items to be terrific and some, such as pneumatic air fittings, to be of very low quality. My concern is whether or not their battery tender is good enough to keep the battery properly charged and will turn down or off at the right time to prevent battery damage. Saving money on a battery tender and have it ultimately destroy the battery seems counterproductive.
Old Mar 25, 2010 | 07:02 PM
gorghamak's Avatar
gorghamak
St. Jude Donor '10-'11-'12-'13-'14
i have used a harbor freight battery tender for 3yrs. with no problems
Old Mar 25, 2010 | 07:31 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
no problems on my end...
Old Mar 25, 2010 | 07:59 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I had a post on battery tender info. The most popular one seems to be the Battery Tender Plus, but there were also a lot of those the use the $10 Harbor Freight battery tender and have not had any issues. I just order one, for $ 16.98 (includes the shipping) I guess you can go wrong.
Old Mar 25, 2010 | 08:13 PM
2KFRC5's Avatar
2KFRC5
I've had mine for about 6 years. Its been flawless. I hook it up with the battery in the Vette, all connections intact.
http://www.harborfreight.com/manuals...2999/42292.PDF
Old Mar 25, 2010 | 08:28 PM
Greg_E's Avatar
Greg_E
I bought mine with one of their coupons for S3.99 They seem to work fine.
They look to be a knockoff of this one which I've had for many years.
http://www.sportsimportsltd.com/gues...t-charger.html
Old Mar 25, 2010 | 09:04 PM
Exoray's Avatar
Exoray
In all honestly probably not a knock off but the same item from the same manufacture, just rebranded at a higher cost... You will see this happen to A LOT of the items HF has had over the years, they pop up at another store for 3-4 times the cost...
Also the float chargers they sell are fine, but do note that by design they are for keeping an already charged battery topped off not charging it, so in short they are for storage not charging, that is the whole concept of float chargers...
Old Mar 25, 2010 | 09:33 PM
ROJ#79's Avatar
ROJ#79
I also have used them for three years o0n my Vette and S-10 P/U.
Old Mar 25, 2010 | 09:36 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Going on two years now with my Harbor Frieght tender, no problems at all
Thanks,Matt
Old Mar 25, 2010 | 09:45 PM
davek 515's Avatar
davek 515
Bought one this year with no problems.
Old Mar 26, 2010 | 04:48 PM
kh400's Avatar
kh400
I've used their float charger on one of my motorcycles. Worked well but quit after less than a year. I found a better one at Walmart for around twenty dollars and I have several of those that have been working for two plus yrs. Just my $.02. Good luck!!!
Old Mar 26, 2010 | 05:49 PM
carhodge's Avatar
carhodge
I use them on my riding mower and my 67 camaro,they work greart,but never drop one.ask me how I know.Cheap,but work good.
Old Mar 26, 2010 | 09:45 PM
dbbspider's Avatar
dbbspider
I bought one of these for $20 and it works fine. I like HF but I like Diehard better
Old Mar 27, 2010 | 02:11 PM
ytwokc5's Avatar
ytwokc5
Been using the Harbor Frieght $10 tender for 4 years, no problems at all.
Old Mar 27, 2010 | 02:34 PM
34RedRage's Avatar
34RedRage
i use 9 hf tenders in the winter on different batteries, including my vettes, ATVs, toy box and riding mower, never a problem with any of them.
Old Mar 27, 2010 | 03:08 PM
Dave1998's Avatar
Dave1998
same here
Old Mar 27, 2010 | 03:11 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I have 3 of them that I use on my Corvette, Boat, and Garden Tractor batteries during the off season. They're all at least 5 or 6 years old, and they all still work great.
You can't find a better bargain on a battery float charger, than these from Harbor Freight.
To Harbor Freight Battery Tender
Old Mar 28, 2010 | 12:30 AM
rws.1's Avatar
rws.1
5th season for my '01 on the Harbor Freight Battery tender
3rd season for my wife's '04 on a second one
2nd season for my '08 after using it for 4 seasons on my '88..
Why spend more unecessarily
Old May 11, 2010 | 12:27 AM
mag red vette
Does the battery tender remain on the battery all the time when the car is stored or does it have to be turned off and removed once the battery is topped off? Also, do the battery caps have to be removed to prevent explosions?
Old May 11, 2010 | 10:21 AM
2KFRC5's Avatar
2KFRC5
The HF one stays on all the time while in storage, as it maintains the battery. It is a Float Charger, so your battery should begin with a full charge, as it is not designed to charge a low battery.
Battery caps remain on.
