[Z06] What Handling mods to do?
I'm looking to upgrade the handling of my 02 C5 Z06.
The suspension is too much comfort orientated for my liking, i just don't feel the car like i do with other cars.
What i want is flat cornering and a much more precise steering.
Especially the wobbly front end is bothering me, i want the nose to steer in the moment i turn the steering wheel, not 2 seconds later
On the motorway i'm all over the place even tough i don't seem to have worn suspension bits.
Can you please recommend me some mods?
I was thinking:
- phadt coilovers?
- 18/19" wheels?
- polybushed wishbones or bearing mounted wishbones?
Thanks, Xav
First, since it is an 02 I'm assuming that you have a goodly number of miles on the car, it isn't likely to have the OE tires on it. Get a set of serious tires mounted up. Soft sidewalls are one of the biggest culprits in robbing you of steering response, and if you have a set of mushy tires on the car all of the suspension mods in the world aren't going to do much good.
Second, again based on the age, the stock shocks are likely shot. They don't last all that long and after 40,000 miles are mush. Get a set of Bilstein sports or the stock 04 Z06 shocks, or a set of C6 Z06 shocks. These are all much better than the shocks that were new on an 02Z and will transform the handling.
Third, get a new set of upper control arms (that's the only way to get new bushings) and have them installed when you do the shocks. The old bushings again, based on age are probably shot and that is where a good bit of the rubbery response is coming from. Same as with the tires, if your bushings are shot, all of the expensive parts thrown at the car won't make it any better.
Lastly, lower the car PROPERLY (do not slam the car to the ground, lower it about an inch) and get it cornerweighted and aligned. Put in an aggressive street alignment with about 1.5 to degrees of negative camber in the front, about 1 degree of negative camber in the back and about 1/8 of an inch of toe in all around.
AFTER you do all of that if you aren't satisfied with the car, then think about mods, but do the maintenance stuff first and you will very likely be amazed how these cars can handle. But throwing money at the problem before you fix what is most likey wrong with the car up front is just an exercise in frustration.
step 2: coilovers and corner weight
If your car has a "wobbly" front end, slow response, and too much body roll, then something is wrong. Modding is not the answer.
Two schools of thought on handling generally IMO, stiff bars/soft springs, or stiff springs/smaller bars. Both options need the appropriate shock to control them. Third option is the coilovers. Both LG and Pfadt have fans and successes, but I have no personal experience.
I would start with the shocks, inspect the bushings and go from there. If you don't care about ride quality, you could go stiffer springs, appropriate bars, poly bushings (or spherical if you are really hardcore) adjustable shocks, alignment and corner weight. Will definitely make a large difference when done together vs factory handling; but the factory car is pretty damn solid. I don't know what you are used to, but you may just be used to over sprung, over barred cars near the bumpstops.
Enjoy the ride and do some research, might be worth wandering over to the Road Race and Autocross section and checking to see what the pros and wheel to wheel guys do.
Fej
My 04Z, I installed Pfadt coils, Pfadt fatty race bars, and trans mount. I did Pfadts street/race alignment and a corner weight with me in it. The car is now a super car it handles very flat and the coils are set on 8 and sways neutral. I also have a 18/19 set up with PS2's. A major improvement now just need to change my seats,can't stay in them around off ramps.
The other option to save money and get killer results. Lower the car about 1/2", change shocks to a Pfadt inverted shock or similiar, and a set of pfatty bars. Align the car to Pfadts street/race settings and this will be a major improvement more then you can use on street.
If the front end seems loose no matter what option you go with you need to check and or replace bushings. As these things get old you can be losing a inch of camber in all turns.
I was thinking:
- phadt coilovers?
- 18/19" wheels?
Thanks, Xav
You really need a target amount you are willing to spend. Consider that an '02 Z06 is only worth about $20-25,000. Are you willing to spend $10,000 on suspension to get the improved handling you're looking for? Also 18/19 wheels are not going to make the car handle any better. Spend your wheel money on grippy tires for much better effect.
If you choose to proceed here are a few options:
1. Koni FSD/Bilstein/C6 Z06 shocks and some Hotchkiss/T1 bars. Probably less than $2000.
2. Complete Pfadt package including coil over shocks, sways, bushings, and camber kit. Total is less than $4000 USD.
3. Same mods of sways, bushings, and camber kit, but upgrade to the fancier and more expensive shocks LG's, DRM Penske's, or other premium race shocks. The fancier shocks are going to be about $3500+ just for the shocks.
Good luck whatever you choose.
Dog
The car has 45Kmiles on the clock, suspension is is 100% stock, it's never been raced or been in an accident.
I have a set of spanking new Michelin pilot sport PS2 tires on (i'm not the kind of guy that buys the cheapest tires, i want the best ones)
The car is a little lower than normal and the alignment has been done recently witht the standard Z06 settings.
I don't see any worn parts like track rod ends, bearings, the shocks pass the vehicle inspection obviously but haven't been tested any further.
I am willing to spend a little money on the suspension, 5-6K sound about right. I don't want to have a die hard track setup, just a stiff ride that will cope with the usual bump in the road.
I might go with the phadt package, it seems to be good value for money and install new front arms. Are the LG 2's supposed to be better than phadt?
Does anyone have suspension arms mounted with bearings instead of rubbers/PU bushes? I have this on my other car and it's great.
2 pics of my car to show you i'm serious in maintenance and keeping the car clean.
p.s. the catbacks on the photo were temporarily, just to pass the noise tests here in France
....GOOD seats the best handling mod I have done hands down...
You will not believe how you will be able to drive your car when properly supported.
Add the LG GT2 coil overs I put on, and WOW ! Just crazy how this car drives now.
Toque
The pics shows them installed in a C6.... does that mean they fit C5?
They look awesome!
I know what you mean...
Modding can be a curse.
I'm not sure what else I will do. I got Coil overs, and Corbeau A4 seats this year. There is nothing I "need" for my car of course. No plans for anything this year (wife is gonna shoot me)....
Toque
