Tire depth question
Old Mar 26, 2010 | 11:56 AM
Kingman99's Avatar
Kingman99
Default Tire depth question
Hi
My orig Goodyear run flats (2002) which happen to be awesome shape has appro 17,000 miles on them and l picked up a tire gauge that says that l have 6/32's left.
Question when do l have to think about replacing them miles wise?
I will replace them with the new Michelins RF's
Alan
Old Mar 26, 2010 | 12:14 PM
87SAM's Avatar
87SAM
When new, the fronts were 10/32 and rears 11/32 so, you have many miles worth of tread left. With age the compound becomes harder which can limit traction. You would be the best judge of whither or not you are feeling a loss of traction because of that.
Old Mar 26, 2010 | 02:02 PM
Gideon's_Test's Avatar
Gideon's_Test
As 87Sam has suggested, in your case, the tire's age is far more of a concern than the mileage or tread depth. Seven years is the recommended age limit for tires. This is due to the hardening of the tire compound.
Old Mar 26, 2010 | 02:16 PM
Kingman99's Avatar
Kingman99
Your both correct and even though they spent most of their life in a garage l can feel them starting to get harder.
Last week l had to move to avoid an uncoming truck where l was probably at 35mph and climbing when l had to stomp down and the back wiggled. But this could have been from the street tune l just did which changed the shift points plus the blackwing that was put on and l'm forgetting something.
Anyway l should plan on switching my tires by the end of the summer for sure. Probably will stay with the runflats and go with the Michelins.
The sad part of living in NJ is that there is no place to play.
Alan
Old Mar 26, 2010 | 02:21 PM
Gideon's_Test
Hey, there is always autocross and drag racing & road courses! Playing is great!
Old Mar 26, 2010 | 02:48 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
englishtown is still around isn't it?? i would think there are plenty of winding roads in western NJ (of course i haven't been there in many years and it may all be walmarts by now, lol).
Old Mar 26, 2010 | 02:52 PM
Minimum tread depth is 2/32nds, but I always replace mine before then. I usually get new tires when the tread is between 3/32nds and 4/32nds.
To Tire depth question
