lights out
Old Mar 27, 2010 | 06:02 AM
redrager's Avatar
redrager
Default lights out
I have a 98 Corvette.The problem ;sometimes the hideaway lights will not open;the only time it happens is when the engine is warm;when it is cold;no problem.It seems that once the engine cools down they will work again;any ideas
Old Mar 27, 2010 | 12:17 PM
cookrent's Avatar
cookrent
St. Jude Donor '08
Check your light connections and grounds. I think there are 5 differnt grounding points. Clean and greese all connections. Do you hear any sounds from motors, when they do not work? Gears go bad sometimes. I have a 98 but no light troubles yet.
Old Mar 27, 2010 | 12:46 PM
cookrent's Avatar
cookrent
St. Jude Donor '08
Try this
http://forums.corvetteforum.com/c5-t...tion-long.html
To lights out
