[Z06] Code Help Needed
Old Mar 27, 2010 | 08:29 PM
slong's Avatar
slong
Default Code Help Needed
Received several codes all at once. Just cruising around, but in some stop and go traffic when I noticed the check engine light was on. 2003 Z has approx 13K original miles. Also engine has long tubes, straight through cats with sensors, dual springs and a tune added about 500 miles ago. Can someone offer up some info on the underlined codes please? Was this just a communication issue with the BCM, or did I develop a ground issue somewhere? Replies will be greatly appreciated.
10-pcm (P0420 HC) - Not listed but I think it is System Low Efficiency Bank 1
AO-LDCM (U1064H) - Loss Of Communications With BCM
A1-RDCM (U1064H) - Loss Of Communications With BCM
A6-SCM B2505H) - Not listed but I think it is Seat Front Vertical Position Sensor Failure
All the best,
slong
Old Mar 28, 2010 | 12:18 PM
slong's Avatar
slong
Glad to see everybody is out enjoying there weekend.
Old Mar 28, 2010 | 12:57 PM
slvrzo6's Avatar
slvrzo6
All the best,
slong
The Codes with just a H after them are History Codes, Just write them down and clear them out.
The PO420 HC is the only current code.
Basically it's a drivers side catalytic converter efficiency issue.
Loose manifold/header.
Bad Cat or leaking Cat.
Rear o2 sensor weak or needs replacing, check the wiring and connection there too. Make sure nothings touching or melting.
Hope this helps.
Old Mar 28, 2010 | 01:07 PM
slong's Avatar
slong
Thank you very much sir, greatly appreciated.
Old Mar 28, 2010 | 01:17 PM
slvrzo6's Avatar
slvrzo6
No prob.. Good luck with your repair!
To Code Help Needed
