12 c.d changer
Old Mar 28, 2010 | 05:24 PM
guyzc5's Avatar
guyzc5
Default 12 c.d changer
i have a 12 c.d. changer in the trunk of my c-5 conv. while driving going over the slightest ripple in the road it pauses for a milisecond,it is just an inconvience, were there any recalls ? i only have 8,500 mi.on the car. has anyone had this same problem? and if so what's the fix. any suggestions ?
Old Mar 28, 2010 | 05:30 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
You have to keep in mind the unit is now anywhere from 6 to 14 years old, You can try to have it cleaned and adjusted, That might help.
Old Mar 28, 2010 | 05:44 PM
CatCam's Avatar
CatCam
guyzC5-
I have a 2004 C5 and had similar issues - the fix? Bypassed the CD changer so I can use my old Sansa (IPOD).
Here is what you will need to get....less than $80, provided you have an IPOD or Sansa, Zune....
1. PIE GM10-AUX
2. 3.5MM-RCA CABLE - 10 feet long
3. IPOD or equivalent
I just did this to mine, posted in the audio section.
http://forums.corvetteforum.com/audi...x-oh-yeah.html
Hope this helps!
Old Mar 28, 2010 | 05:52 PM
Mr.Bill's Avatar
Mr.Bill
Originally Posted by CatCam
guyzC5-
1. PIE GM10-AUX
Hope this helps!
The only trouble with going this way is that it will not charge the ipod.
89 bucks from a vendor here and you have best of both worlds.
and can control it from your radio.
http://www.doubledmods.com/Periphera...ter-ipodc5.htm
Old Mar 28, 2010 | 05:59 PM
Tulsa Vette Guy's Avatar
Tulsa Vette Guy
I have the same problem,, I have 2002, with the skipping changer,, I was told to unbolt it and install soft rubbers washers, or place a foam backing to the unit, to take up the shock from bumps. I have not try ed it yet, But on my list to do soon.
Old Mar 28, 2010 | 09:24 PM
abigfoot's Avatar
abigfoot
Slow down Some are sensitive some work fine try cleaning it first.
Old Mar 28, 2010 | 09:35 PM
CatCam's Avatar
CatCam
That is a nice gizmo, the only problem I had with it is that I have a Sansa, my wife has a touch IPOD and my son has a Zune. With my set up I can use all three, I'm not limited to just the IPOD. Also, I usually get 5-6 hours from my Sansa on battery power. I also carry the car charger just in case but I think it will be far a few times that I have to use the charger.
Old Mar 28, 2010 | 10:00 PM
rickko's Avatar
rickko
I've got an '04. Recently the CD changer has been stopping in the middle of tracks then sending ERR to the display and ultimately flipping back to the radio mode.
Or, on tight curves it creates a noticible static sound when playing a CD. I changed the disc pack, the discs, the disc platters, etc. Nothing changes the way its been acting. Took vehicle to dealership (I have $0 deductible GMPP). Service dept. said, "No problem, will install a new player."
My opinion of your problem isn't going to get fixed with more shock absorption unless its done internal the the unit. I think you need a new unit, a used unit from the For Sale section or get yours refurbished. JMO.
..rickko..
To 12 c.d changer
