Aargh! Oil Pressure Sending Unit fell behind engine!!
as the guy on Saturday night live used to say,
you have to wonder who the ad wizard that came up with this idea?
but change it to "wonder who was the engineering wizard that came up with that location."
Thanks for the post. I went to the sticky and found where others had used a round saw on drill. Both look like reasonable fixes to me. I would think with a round hole, some kind of standard size rubber plug could be installed to fill in, providing the curves will cooperate.
If I need to do this I'll call up your post to get an idea to start my cuts. Glad you retrieved the sensor.
My understanding is that there's a GM tool you need to buy....
Banned Scam/Spammer
#33
No special GM tool is needed. I used this one: http://www.harborfreight.com/cpi/cta...emnumber=38732
#35
It's really not necessary to remove the fuel line, but it makes it easier if you do.
#37
The LS1 intake seals to the heads with rubber o-rings that are re-usable. No need to even remove them, just leave them on the intake and reinstall it.
As my daughter would say - easy peasy lemon squeezy.
#39
I like it! Good job...Great alternative solution and now the sensor can break as many times as it wants. Its like changfing a bulb. But yeah id use a hole saw right on top of the sensor for a cleaner install.
