tps training
Old Mar 29, 2010 | 07:30 PM
carhodge's Avatar
carhodge
Default tps training
I'am going for new front tires,and rebuilt tps,do I train just the 2 new or all 4.Oh,98a4.Thanks.
Old Mar 29, 2010 | 07:33 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Once you start the procedure you will have to follow it completely, so yes, you'll have to train all.
1. Turn the ignition to ON.
2. Press the RESET button in order to clear any IPC display warning messages.
3. Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
4. Press and hold the DIC RESET button for 3 seconds.
5. Press the OPTIONS button again until the TIRE TRAINING message appears.
6. Press the RESET button until the IPC LEARN L FRONT TIRE message appears in order to begin the programming sequence.
7. Install the J 41760 (Magnet) over the left front valve stem.
8. The horn will sound, indicating the left front TPM sensor is programmed.
Important
If the horn does not sound after 15 seconds, remove then reinstall the TPM sensor programming tool. This procedure may have to be attempted up to three times in some instances.
9. When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages:
* LEARN R FRONT TIRE
* LEARN R REAR TIRE
* LEARN L REAR TIRE
Old Mar 29, 2010 | 08:03 PM
carhodge's Avatar
carhodge
Thanks,I thought so...
Old Mar 29, 2010 | 08:47 PM
Bakersfield's Avatar
Bakersfield
Train them BEFORE you mount them in the wheels just in case one or more of them don't work. Sit in the driver's seat and go through the procedure above and mark them with a marker as to which location they were trained for. Then make sure the tire guy puts them in the correct wheel and puts them on the correct location.
To tps training
