SeaFoam "Lite"?
I have both Seafoam in liquid and the spray form "Deep Creep" in the garage.
If I wanted to put the liquid form in gas tank and then used the spray via the throttle body while the car is running (at the end spraying enough to stall it, wait 30 min, restart, small smoke show)....will I need to change the oil after doing that? Does this process basically doing the same thing as taking the liquid form via a vacumme line?
Basically at what point do you have to change the oil when using this stuff?
JMHO
Just putting it in the gas should not be a problem, but, it will not clean the throttle body or the intake, only the fuel system.
Trade off.
Now some have used seafoam in the crankcase prior to an oil change. I just dont see where the seafoam and oil are crossing paths through the intake, should just be air in there.
I have been wrong before though...
