[Brake Bleeding] Need Assistance.
Old Apr 3, 2010 | 11:32 PM
robsc501's Avatar
robsc501
Hi There;
Sounds to me like your master cylinder needs replaced or new o-ring kit installed.
robsc501
Old Apr 6, 2010 | 12:21 PM
don37's Avatar
don37
Veteran: Canadian Forces
I suspect you will have to bench bleed your master cylinder. this will make a world of difference!! Dont worry - it wont have to come off the car.
Old Apr 6, 2010 | 03:41 PM
DIXZ's Avatar
DIXZ
Is it possible that the calipers were put on the wrong side of the car? Your bleeder valves need to be at the top of the caliper!
Just throwing it out as I have seen this in the past.
Old Apr 6, 2010 | 04:33 PM
TEXHAWK0's Avatar
TEXHAWK0
If you let the master cylinder go dry, you should bench bleed it, and burp the air out of the ports when you connect the lines. You should not see any bubbles coming up in the reservoir if the master cylinder is bled correctly.
As already mentioned, make sure the bleeder valves are at the top or you will never get all the air out.
I bled my whole system and replaced the master cylinder with less than a quart of brake fluid.
Have you looked at the base of the master cylinder to see if there is any fluid running down the front of the booster?
