Rear View Mirror
Apr 2, 2010 | 10:00 AM
Rear View Mirror
My rear view mirror on my 99 C-5 has a map reader light out on the right side. It is the light you can turn off and on. Does the lens pop out? I assume it is a bulb that needs replaced. Has anyone had this problem and if so what did you do about it?
Thanks for your information Dave
Apr 2, 2010 | 01:00 PM
St. Jude Donor '11-'12-'13-'14-'15
Yes the lense pops out, I believe the bulb is 44mm Festoon bulb or a 212-2...
Apr 2, 2010 | 02:26 PM
just use a very small flat-head screwdriver and GENTLY pry the sides of the lens...you'd need to remove your mirror to make it easier by using a torx screwdriver....
I also have a 99 coupe, soon to replace lights with LED's (yes they are festoon bulbs)
Apr 2, 2010 | 02:38 PM
i replaced mine with the leds in red freaking awsome man. best and cheapest mod u can do
Apr 2, 2010 | 02:51 PM
Quote:
Originally Posted by
tom01ss
except i did blue LEDs. They look sweet!!
Apr 2, 2010 | 03:29 PM
OK... I'll play too. Red LEDs!
I converted an autodimming mirror into my 99 though so those aren't festoons but LED arrays...
Tim
Oct 4, 2010 | 03:33 PM
Anyone know what the standard bulb GM part number is, or the bulb trade number?
Thank you.
PS - My dealer said he could not find a listing for this bulb - I have one burnt out.
Oct 4, 2010 | 03:59 PM
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
1999 White C5 Coupe
Thank you.
It should be a 212-2 bulb
Oct 4, 2010 | 05:48 PM
Mr.Bill
Thank you!
2000 ,
bulb ,
bulbs ,
c5 ,
corvette ,
corvetter ,
donnellys ,
led ,
mirror ,
rear ,
replace ,
replacement ,
standard ,
view
