This was one of my first mods. From the first drive you could feel the difference in throttle response. The only draw back is it's a true bottom breather, you can not drive through standing water that could be sucked into the intake, you also have to cut the fan shroud. I have the clear one so you can see the filter.
Have had mine installed since mid last summer. I have had no problems with it and love the look as I show. It makes for a cleaner look with the hood up.
Laurie
My Vette had one on it when I bought it-no complaints except reinstalling the filter after cleaning can be a challenge.
I did a little mod on mine to hold the filter element in place while I slip the MAF into it,saves alot of time and cussing....
I've had mine almost 10 years and am 100% pleased with it. No desire whatsoever to change. I find removal of the filter to clean and re-install a rather simple procedure.
