Build date for 2004 CE
I've got this earlyer, http://www.compnine.com/vid.php?
but it dos'nt work for this vin.
Where do I by the ORIGINAL Gear ****, Shale, A4
Allan
Lots of C5 owners have "upgraded" to some other shift **** so I agree, try posting a WTB in the Forum parts section. Hopefully some CE owner has the original laying around. If you can't get the proper color, you can have any C5 A4 or manual shift **** recovered by a few of the forum vendors in the proper Neutral color. Shale is the sort of cream color and the darker color is called Neutral.
http://www.c5registry.com/MembersOnl...2004/index.htm
Allan
Denmark
VEHICLE BUILD
Merchandising Model : 1YY67 -2004 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1673 kg (3689 lb) Order Number : GHXSGZ
Build Date : 08/08/2003 Build Plant : 145Y
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C05 - CONVERTIBLE FOLDING ROOF DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE3 - SPORT SUSPENSION FE9 - 50-STATE EMISSIONS
G90 - REAR AXLE-3.15 RATIO G92 - AXLE: 3.15 PERFORMANCE RATIO
IL2 - TRIM INTERIOR DESIGN JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI V8 - 350HP
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NK4 - LEATHER WRAPPED STEERING WHEEL NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN QF5 - HIGH POLISHED ALUMINUM WHEELS
SLM - STOCK ORDERS T82 - TWILIGHT SENTINEL
UL0 - AM/FM CASSETTE STEREO UV6 - HEAD UP DISPLAY
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U1S - CD 12 DISC CHANGER, REMOTE
U52 - ELECTRONIC INSTRUMENTATION U75 - POWER RADIO ANTENNA
VDC - VEHICLE INFORMATION CD VM3 - CONSUMER INFORMATION LABEL
V49 - LICENSE PLATE FRAME: FRONT V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR
Z15 - COMMEMORATIVE EDITION Z51 - PERFORMANCE HANDLING PACKAGE: (INCLUDES STIFFER SPRINGS AND STABILIZER BARS)
1SC - COMMEMORATIVE EDITION * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN * COMMEMORATIVE EDITION 1SZ - PREFERRED EQUIPMENT SAVINGS
15I - SHALE INTERIOR TRIM 152 - SHALE COMMEMORATIVE
19U - LEMANS BLUE 54T - SHALE
