I'm in the market for rotors, and many of the websites only offer generic pictures, not pictures of the actual rotors for the C5. I would appreciate it if Forum members could post pictures of the various brands available, such as Stoptech, Baer, Powerslot, DBA, etc. on your car.
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I don't remember where I bought these, but they weren't expensive at all and work great so far. They look a lot better than the rusty stock rotors I replaced.
I'm using Girodisc (A1-009 & A2-009): Self centering radial float mount rotors with 6061-T6 aluminum hats and cast iron curved vane / slotted discs (attached using cadmium plated alloy steel drive pins with grade 12 cap screws and hardened anti-noise spring washers). For pads: Federal-Mogul Ferodo Racing DS2500s (0.50 coefficient of friction at all temperatures) and braided lines.
Considering I run this car on both street and strip (she runs a 9 second / 145 mph qtr), these were my choice as they fit inside a CCW drag pack, are light weight (hard to find 2-piece rears in a stock size) and, most importantly, they stop the car better than any other combo of rotors and pads I've tried.
They have a web site you can check out at: http://www.girodisc.com/ -- I think it will depends on your make, year, model, etc., and what rotors you select, which is why I provided the part numbers that I ordered for my '03 coupe.
I am sure they are far from the cheapest. But, I wanted lighter two-piece front & rears that would fit inside a CCW drag pack and retain my parking brake, while effectively stopping the car from high speed on a drag strip. At the same time, they needed to work perfectly for street driving.
Originally Posted by JohnsC5
Baer one piece rotors. Have 40k miles on them. They're guaranteed not to warp.
I had the same rotors on my '00 - loved them. Zinc coated to prevent rust and great looks. If I replace my stock rotors, I will definitely consider another set of the Baer's.
Just drilled and slotted? Nothing else fancy about them? They look "More Shinny" then most the others I see.
Price? Any forum vendors sale these?
Those are Baer Declarotors. Same as the ones I have. Zinc coated is the key. Mine look as good now and the day I put them on. Expect to pay around $450 for a set (if memory serves may have gone up). I got mine from ajusa.com. They had the best price back then.
The picture looks a little dull compared to real life. They really look nice in person.
Reason: Added picture
From: Wylie TX --> Less is More, except under the hood !
Bear Eradispeed Front and Rear Rotors. 2 Piece rotors - Aluminum centers.
Front 13.35" (stock is 12.75")
Rear 14" (stock is 12")
They are just a pinch "lighter" than stock.
The rear 14" will even fit behind the stock 18" rim. You will have to get the 12.75" 2 piece Bear rotor for the front 17" rims though. The 13.35" will not fit behind the 17" stock rim.
