Rev limiter question
Old Apr 7, 2010 | 09:56 PM
Aerovette's Avatar
Aerovette
Default Rev limiter question
Ok, my pure embarrassment prevents me from telling you how it happened, but I ended up over-rev'ing for a very short time and bounced off the limiter. It is a fairly low mile engine (19K). Harm or no harm? I don't know if the limiter prevents damage or just prevents it from blowing.
Old Apr 7, 2010 | 10:01 PM
Jet-Jock's Avatar
Jet-Jock
It is there to prevent damage.
Old Apr 7, 2010 | 10:08 PM
2KFRC5's Avatar
2KFRC5
Did you over rev it, or just hit the limiter?
If over revved, you may luck out.
Old Apr 7, 2010 | 10:09 PM
Aerovette's Avatar
Aerovette
More embarrassing than that...it's an AUTO. Don't ask.
Old Apr 7, 2010 | 10:10 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Unless you accidentally dumped it into a lower gear and over revved that way. Then the rev limiter offers no protection.
That can cause damage.
Old Apr 7, 2010 | 10:18 PM
Aerovette's Avatar
Aerovette
Ok ok, I bumped it into neutral under acceleration !!!!!!!
Old Apr 7, 2010 | 10:35 PM
luckeman's Avatar
luckeman
In that case your just fine, it wasn't a mechanical over rev.
Old Apr 7, 2010 | 10:56 PM
2KFRC5's Avatar
2KFRC5
Rev Limiter should have done its job.
Old Apr 7, 2010 | 11:12 PM
tlc0706's Avatar
tlc0706
Should be fine....Hope no one saw it though..
Old Apr 7, 2010 | 11:21 PM
Aerovette's Avatar
Aerovette
I was alone. I was entering the highway and "thought" I was going from 3 to OD, but was actually going from OD to N...under aggressive (not full) throttle. I had the music up and the stock exhaust is quiet and I VERY QUICKLY realized I was not gaining speed. It all happened fast but it seemed like a lifetime.
To Rev limiter question
