Help with helmet selection
Old Apr 8, 2010 | 03:25 PM
olefam's Avatar
olefam
Default Help with helmet selection
I will be going to a performance driving school for the first time and I am supposed to bring a "snell 2005" certified helmet. Years ago I rode motorcycle and am somewhat familiar with helmets, but I am not sure what I should be looking for in a helmet used for automobiles.
Is open face or close face better? Is the "M" or "SA" rating preferred? Do I go "cheap" or do I have to spend $500.+ to get best protection?
Any adivice would be appreciated.
Glen
Old Apr 8, 2010 | 03:50 PM
casisthefirst's Avatar
casisthefirst
I started riding a few months back and I did tons of research on helmets as well...
Turns out that the "cheaper" helmets offer the same, if not better protection than some of those high-end helmets. My advice is get a relatively inexpensive helmet (~$200) and make sure its DOT and SNELL approved. That will protect you against low and high-speed collisions
Old Apr 8, 2010 | 05:32 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
You want Snell SA, M is Motorcycle and not all auto venues will allow them.
I've found a few full face Snells 2005 SA for @ $200.
Old Apr 8, 2010 | 06:11 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
I'm a BIG fan of Full Face.. on a Motorcycle. In a car it's just too confining and hot! There's not enough air moving through there. You may not get to have your windows down at school. I got an open face Snell SA off ebay for less than $150.
Old Apr 8, 2010 | 06:47 PM
KeyoRacing's Avatar
KeyoRacing
I got the coolest damn helmet off ebay for than $100... Love it.
And I can't see any difference from it and some other helmets I've had in the past. I agree with the other post in some cases you're paying a lot for the name. I have no concerns about the helmet I got at all.
Old Apr 8, 2010 | 07:05 PM
jrose7004's Avatar
jrose7004
I've always heard that if you have a $100.00 head then get a $100.00 helmet!
Old Apr 8, 2010 | 07:11 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
The "M" is for motorcycle. This helmet has a nylon inner liner. Some auto race venues accept them others don't. Check with your organizations requirements.
"SA" rated helmets are designed for automobile use. They are designed to hold up to multiple impacts (such as hitting the roll bar) it also has a NOMEX interior liner. The Nomex will be better protection in the event of fire.
Old Apr 8, 2010 | 10:11 PM
yaknow's Avatar
yaknow
good info, I'll be checking back as I need to buy a helmet also
Old Apr 9, 2010 | 02:40 AM
Last C5's Avatar
Last C5
The cheap helmet will provide adequate protection, but it will also weigh more than the more expensive helmet. After a long day at the track your neck will thank you for stepping up to the better helmet.
To Help with helmet selection
