fuel pump drainback valve not working
Old Apr 8, 2010 | 04:59 PM
Husker_1995's Avatar
Husker_1995
Default fuel pump drainback valve not working
Hello,
My car loses fuel pressure after sitting and it was diagnosed as a bad fuel pump. Car is a 2001 Corvette. Runs fine other than losing pressure and is hard to start after sitting. I've heard that these pumps have an anti-drainback valve inside. Do I have to replace the fuel pump itself to fix this or is the drainback valve in the assembly somewhere? Does anyone have a diagram?
thanks
Old Apr 8, 2010 | 05:09 PM
dougbfresh's Avatar
dougbfresh
I don't think so. There were also 2 fuel systems in the C5. The early cars had a return line to the tank the later cars had a single line. Probably a leaky injector staying open after the car is off.
Old Apr 8, 2010 | 06:55 PM
Husker_1995
Thanks for your comments. I should explain exactly what the car is doing. I started a new thread in C5 Tech.
thanks
To fuel pump drainback valve not working
