[Z06] 2003 Zo6 no compresion
Old Apr 8, 2010 | 09:53 PM
traviswalker007's Avatar
traviswalker007
Default 2003 Zo6 no compresion
Hey guys,
Im new here and thanks for reading this. I have a 2003 Z06 with 54k miles. It has dynatech full exhaust with headers and longtubes with cats, WCC hurricane intake, 170 thermastat, and was just dynatuned 2 weeks ago at 456hp. The car has driven well since the tune, but yesterday i went to get an oil change at a local jiffy lube. They had done the car before with no issues putting in the mobil 1 syth oil. I left the lube shop and drove approx 10.5 miles and the engine started rattiling and looseing power so i pulled over. Called the lube shop manager and he came out to were i was and looked at the car. Oil is full, oil filter is ok, no oil around drain plug or anywere on engine at all. so i had it towed to a shop. Got a call today and they said the did a compression test and #4 has low to no compression?? but they are still looking into it. They said maybe a bad valve, rod, lifter or whatever im no mechanic. Does anybody have any idea what may have caused it. The car was running fine with no issues at all then bam... it sounded like it was running on 1 cylinder and rattiling and knocking. Any advice would be helpfull so i dont get taken for a ride..
Old Apr 8, 2010 | 10:15 PM
UmCanesZ06's Avatar
UmCanesZ06
I'm gonna bet it's a blown head gasket.
Old Apr 8, 2010 | 10:24 PM
ctusser's Avatar
ctusser
Possible broken valve spring and or valve. That rattling could be Piston hitting valve. Hopefully your head, piston and cylinder are OK.
Old Apr 9, 2010 | 01:07 AM
RogerZ06's Avatar
RogerZ06
You should of kept going and seized that engine. Then jiffy lube would buy you new one.
Old Apr 9, 2010 | 01:18 AM
ptindall's Avatar
ptindall
Ummm...no. Taking the car to Jiffy Lube is a pretty bad idea, but it sounds like they did nothing wrong. Why would they have to pay for anything?
Headers and longtubes are the same thing. And how did you come to 456hp? Some calculation of assumed drive train loss? It's better to just state what it made at the rear wheels instead of guessing what that means at the crank.
Old Apr 9, 2010 | 09:01 AM
81c3's Avatar
81c3
Put me in the "broken valve spring" crew. It sounds like that could be the problem. Pull the valve cover and look at the springs.
To 2003 Zo6 no compresion
