Check Gauge Messages
I have been getting lately the below messages:
Service ABS
Service Active Handling
Service Traction Sys
I usually reset them and they go away until the next drive I take the car for a ride. The car seems to drive fine. Also sometime I get those messages a minute after i start the car and sometime in 20min
I would like to know what am I dealing with, is that kind a warning to change the brakes or maybe a sensor is bad, etc. I want to have an idea what i am dealing with and if that something i can fix on my own or maybe reset something
ANy input on that is greatly appreciated
Thank you
Post up your codes...
Nick
Nick
28-TCS; C1221H, C1225H, C1232H
40-BCM; B2592H, B2723HC
A0-LDCM; B2282H, B2284H, U1064H
A1-RDCM; B2283H, B2285H, U1064H
A6-SCM; B0851H
B0-RFA; C2115H, U1255H
The rest had NO CODES
Let me know what you think
Update:...I read the thread, link in Post 2. Well looking at the codes I have C1221H; the wheel speed sensor circuit, the problem is which one. Does anyone have pictures, am I moving in the right direction.
But then I have the code B2723HC - PASS-Key Detection Circuit, is that coz i have the car turned on ignition without starting the engine
28-TCS - Traction Control System
C1221 LF Wheel Speed Sensor Input Signal is 0
C1225 RF Excessive Wheel Speed Variation
C1232 LF Wheel Speed Circuit Open or Shorted
So my problem is the Driver and passenger front wheel speed sensor. What do i do from here.
http://www.corvetteactioncenter.com/...+Trouble+Codes
You can export to PDF and save on your computer (click in the box on the right side of the page)
It sounds like you may have a bad battery, or at least that's where I would start looking. The 2282, 2283...are issues regarding the battery.
Bad batteries can cause lots of issues that seem unrelated.
Nick
Nick
What about the below codes they could be coz of the battery or m I looking at 2 different issues
IS that a good idea. I just dont know how old the codes are!!
28-TCS
C1221 - LF Wheel speed sensor input signal is 0
C1225 - RF Excessive Wheel Speed Variation
C1232 - LF Wheel Speed Circuit Open or Shorted
40-BCM
B2592 Column Lock/Unlock Drive (B)
B2723 PASS-Key Detection Circuit
A0-LDCM
B2282 - Battery #1 Fault
B2284 - Battery #2 Fault
U1064 - Loss of communication with BCM
A1-RDCM
B2283 - Battery #1 Fault
B2285 - Battery #2 Fault
A6-SCM
B0851 - Battery 1 Out of Range
B0-RFA
C2115 - Left Rear TPM sensor malfunction
U1255 - Serial Data Line Malfunction
If the condition causing them is still there or intermittently there, they will come back.
You have to read a bit about this system. There are many many posts here (and in the tech section) about codes and what ultimately caused them.
A bad battery can cause the AH/TC system to throw codes that are not being set due to bad components. Once you are confident the battery is good, a bad ground (you will find many posts on that also, start with this one
http://forums.corvetteforum.com/c5-t...c-c1243-h.html
Then do a search for the poster you see in it (Bill Curlee) he has done a bunch of good posts on how/where to check/fix ground issues).
If the battery and grounds are good, the codes being thrown will point to which component needs to be replaced.
Good luck
So I just got home and did the Daignose to see what codes I have and below are the only codes I have. The other codes I guess where old ones that never were cleared when I installed the new battery, tires, etc
What is the below code, why do I get it, is it because I have an auto starter, if thats the case thats fine right? Unless some one can chime in why i have the below code or i need to replace something.
40-BCM
B2723H C - PASS-Key Detection Circuit
So now to the below codes from 28-TCS. 28-TCS
C1221H - LF Wheel speed sensor input signal is 0
C1225H - RF Excessive Wheel Speed Variation
C1232H - LF Wheel Speed Circuit Open or Shorted
It seems I need to replace something, wheel bearing, speed sensor, connecters. Do I need to take of the tires to get to the sensors, connectors.
Also it seems I have a different problem on the passenger front - C1225H or is that code occuring coz of C1221H & C1232H.
C1232H could it be coz of a short fuse where do I look fr fuses related to those error codes
Thank you all for your inputs so far
The other 3 with H's I clear them and once I turn the car on and go for a ride I get them back. So I have a problem I just have to figure out what it is.
I checked the battery and its good and checked couple of the grounds and they are alright.....
I want to lift the car and check the connectors and might just go and change them...... for both sides and see what happens
Not sure why, but as long as I wait a second or two, I never get the codes.
Thanks in advance
What I did based on the codes it seemed the left front was causing the problems. So i jacked the car up and disconnected the harness. Blew air at both ends and connected it back. So far so good. I will keep my eye on it.
If this doesnt work I might go to the dealerhip and buy and buy a replacement for both sides. The install is simple.
Hope I dont get the error and what i did works for a while
RB
