C5 pcm relearn questions
Old Apr 9, 2010 | 11:43 PM
209TIME!!!'s Avatar
209TIME!!!
Default C5 pcm relearn questions
What is the proper procedure to use if i want to try this?
is this process even real or just one of those urban myths?
any forum members have proof that this really works?
i have been wondering about this after reading another thread a couple of weeks ago.
thanks guys for any info.......
Old Apr 10, 2010 | 11:06 AM
87SAM's Avatar
87SAM
Idle Learn Procedure
Anytime the powertrain control module (PCM) or the battery is disconnected, the PCM loses power, or the PCM is reprogrammed, the PCMs learned idle position is lost. The engine idle is unstable when the learned idle position is lost.
Perform the following procedure in order to return the learned idle to the correct position:
Automatic Transmission
Turn OFF the ignition.
Restore the PCM battery feed.
Turn OFF the A/C controls.
Set the parking brake and block the drive wheels.
Start the engine.
Ensure that the engine coolant temperature is more than 80°C (176°F).
Shift the transmission into Drive.
Allow the engine to idle for 5 minutes.
Shift the transmission into Park.
Turn OFF the engine for 30 seconds.
Manual Transmission
Place the transmission in Neutral.
Start the engine.
Or, you could just drive it!
Old Apr 10, 2010 | 11:08 AM
AU Eagle's Avatar
AU Eagle
St. Jude Donor '08-'09-'10-'11, '14
I had mine tuned by ECS.
Put it back in...hooked the battery back up and drove the car.
No special procedure and no problems.
To C5 pcm relearn questions
