will a 315 fit?
Old Apr 12, 2010 | 04:42 PM
futuretech's Avatar
futuretech
Default will a 315 fit?
Will a 315 tire on a z06 rim fit on the back of a C5?
Old Apr 12, 2010 | 09:52 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
You might be able to squeeze it in---probably will need a
spacer and probably will stick out beyond the fender. Alot
of guys like that look, I DON'T.
Old Apr 12, 2010 | 09:57 PM
futuretech's Avatar
futuretech
I am wondering about the spacer. Is it needed?
Old Apr 12, 2010 | 10:28 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I ran 315's on a 12" rear without sticking out...but I had a custom offset done.
I say go with a proper wheel fit if you're gonna do it.
And a more practical view...
Old Apr 13, 2010 | 12:18 AM
mosimann's Avatar
mosimann
I have it and love it!
Old Apr 13, 2010 | 12:27 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It should fit - I have 305's and I could use more and it would fit too
Thanks,Matt
Old Apr 13, 2010 | 01:13 AM
n8dogg's Avatar
n8dogg
stock wheels/offset and youll rub on the inner fender well. Get 1/4" spacers or custom off set wheel.
Old Apr 13, 2010 | 05:58 AM
99MALLETT396's Avatar
99MALLETT396
More info and pics of those wheels please!! an more of that lady too
Old Apr 13, 2010 | 11:03 AM
CHJ In Virginia's Avatar
CHJ In Virginia
I run 315's on stock Zo6 rear wheels on a lowered car without fit or rubbing problems of any kind. They do not require a spacer. The tires are Kumho V710 race tires. If you are considering a 315, go to the manufacturers web site and get the exact size specs and compare them with the Kumho, if close, they should fit fine. Regardless of what anyone says, there are often substantial differences in actual sizes between different tire manufacturers. A 315 sized Bridgestone can have as much as 1/2" difference in dimension when compared to a Goodyear or Firestone.
Old Apr 13, 2010 | 11:31 AM
futuretech's Avatar
futuretech
To will a 315 fit?
