Lots of codes.
Old Apr 14, 2010 | 12:28 PM
justin_heat05's Avatar
justin_heat05
Default Lots of codes.
I had my vette's exhaust done and they rung off some of the header connector bolts. The bolts were really stiff and rusty so they had to heat them with a torch to get them out.
Are there wires or anything that they may have melted around where the header connects to the pipes?
I am getting active handling light, traction control and 7 codes, some of them are brake switches and wheels sensors. Help appreciated.
Old Apr 14, 2010 | 12:32 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
probably a burnt o2 wire.....happened to my car a few years back....
Old Apr 14, 2010 | 12:45 PM
justin_heat05
how much is it to replace it? does removing the cadiliac converters cause these codes?
Old Apr 14, 2010 | 01:52 PM
dougbfresh's Avatar
dougbfresh
You'll get several codes with no cats.
Old Apr 14, 2010 | 10:20 PM
justin_heat05
crap......anyway to fix that without reinstalling cats. Will magnaflow cats fix it?
Its causing my active handling to not work and abs.
Old Apr 15, 2010 | 04:35 AM
dougbfresh's Avatar
dougbfresh
Those are other problems but you'll get "Catalyst Efficiency" codes for SURE with no cats. Why pull the cats off anyway-it's kinda REDNECK. Pull the codes you have and post them, chances are some of your wiring got disturbed or melted with your exhaust mangling.
Old Apr 16, 2010 | 01:14 PM
justin_heat05
My vette has alot of miles and they smelled real bad on the interstate, so i figured they might be stopped up.
Old Apr 16, 2010 | 01:17 PM
justin_heat05
its the brake/light code, right wheel sensor code, and a couple others, ill get them and post them.
Roostertail's Avatar
Roostertail
St. Jude Donor '06
Post the codes....
Nick
Old Apr 16, 2010 | 01:19 PM
justin_heat05
If i get the codes removed/unrecognized at a dealer or somewhere, will my abs system and active handling start to work again?
My cars been wrecked and the airbag light is on and i removed the smog mechanism thats throwing a code. I need these removed anyway.
Old Apr 16, 2010 | 01:24 PM
justin_heat05
c1225 h
c1232 hc
c1281 h
c1288 h
c1291 h
Thanks for the help guys, this all happened right after i got the exhaust work. Never had abs light or traction control.
Old Apr 20, 2010 | 08:27 AM
justin_heat05
is there a sensor that needs replaced next to the exhaust or can i just replace a wire.
To Lots of codes.
