EASY fix
Old Apr 14, 2010 | 09:15 PM
RSchleder's Avatar
RSchleder
Default EASY fix
I've been putting off tearing apart my center console for several weeks now. I thought I had to disassemble the console to replace the light bulb in the shift selector portion of my A4. I read on this Forum a few days ago that you can carefully "pry off" the clear plastic section of the gear selector,remove the white plastic piece (careful the red selector tab) and see the #194 bulb directly below. A pair of tweezers or small needle nose pliers will remove and insert the bulbs. Re-assemble and you have a lighted gear selector again!!!! This took me longer to type then it did to actually do the bulb replacement. So, hesitate no longer, $2.25 for a bulb and 2 minutes of labor and WALLA- you can see what gear your A4 is in at night. Good luck, Ron
Old Apr 14, 2010 | 09:31 PM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
Nice job. Isn't this forum wonderful?!?!?
Old Apr 15, 2010 | 04:39 AM
dougbfresh's Avatar
dougbfresh
It's VOILA not WALLA FYI http://www.merriam-webster.com/dictionary/voila
Old Apr 15, 2010 | 07:35 AM
RSchleder's Avatar
RSchleder
dougbfresh--magicians say "walla" for magic. To me it was a magic trick not to spend 3 hours disassembling my center console.
Old Apr 15, 2010 | 07:41 AM
Thanks for the info - someday it may come in handy for my car.
To EASY fix
