Disconnecting MAF
Old Apr 18, 2010 | 04:26 PM
VCUFAN's Avatar
VCUFAN
Default Disconnecting MAF
I know this is really a dumb question but how does the connector work to disconnect the MAF? I can't seem to unplug it and I know there has to be a trick that I don't know. Thanks
Old Apr 18, 2010 | 04:38 PM
hotwheels57's Avatar
hotwheels57
There should be a light gray colored flat topped U shaped clip visible on top of the connector. Pull up on it to remove it, first...don't lose it, they tend to fly off into places never to be seen again. A fingernail or small flat blade screwdriver beneath the top will help dislodge it from the connector.
Then pull the male/female MAF connector apart.
Old Apr 18, 2010 | 05:13 PM
VCUFAN's Avatar
VCUFAN
Thank you. I figured there was something that needed to be done with that gray piece. Appreciate the help.
To Disconnecting MAF
