Hot rubber smell
Old Apr 19, 2010 | 01:36 PM
Burgie's Avatar
Burgie
Default Hot rubber smell
Every time I drive the 03 vet for fifty or so miles and stop, there is a odor similar to hot burning oil and or rubber. No, there has been no burning of the tires, no emg brake on and no hard use of the brakes. I have noticed a slight oil residue on the leading edge of the left rear, over the axle, down side of the exhaust pipe but nothing on the right side.
But when opening the hood, the smell seems to come from that area also and I first thought it was the fan belt. Anyone got any ideas?
If some one has lost the differential seal, was there any particular odor (outside of depression) noted where oil may be spraying onto the hot exhaust system?
Old Apr 19, 2010 | 04:52 PM
Burgie's Avatar
Burgie
No similars??
Old Apr 19, 2010 | 05:19 PM
bobby777's Avatar
bobby777
Maybe--Just maybe you picked an old used Trojan and its glued to the exhaust--
Old Apr 19, 2010 | 06:48 PM
Cybermind's Avatar
Cybermind
See my post. This is what was causing the burning rubber smell in mine:
http://forums.corvetteforum.com/c5-t...ber-smell.html
Hope it helps.
Old Apr 19, 2010 | 07:09 PM
Roostertail's Avatar
Roostertail
St. Jude Donor '06
Hope it helps.
This is a good place to start looking.
Oil residue on the over the axle exhaust pipe could also indicate a leaky rear differential.
Nick
Old Apr 19, 2010 | 07:57 PM
Burgie's Avatar
Burgie
thanks, will check it out
Burgie's Avatar
Burgie
thanks also
To Hot rubber smell
