Competitive mode.
Old Apr 19, 2010 | 11:08 PM
vetteboy850's Avatar
vetteboy850
Default Competitive mode.
Do all c5 have this? Because i have a 98 c5 and i cant seem to turn it on.
Old Apr 19, 2010 | 11:10 PM
versatile's Avatar
versatile
are you holding the traction control button down for 3+ seconds?
Old Apr 19, 2010 | 11:58 PM
Turbopower87's Avatar
Turbopower87
On your 98 I think you have to be stopped, maybe even have the e-brake on, in order to turn it on. You have to hold it for 5 seconds or so.
Old Apr 20, 2010 | 01:19 AM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
On my 99 A4 I have to be stopped and hold for 5 seconds (feels like forever) but the e-brake can be off
Old Apr 20, 2010 | 01:34 AM
corvettedaddy11's Avatar
corvettedaddy11
What does it do???
Old Apr 20, 2010 | 01:46 AM
BigTattooMan
St. Jude Donor '10
Originally Posted by corvettedaddy11
What does it do???
It turns off traction control but leaves on active handling. Basically lets you spin the tires while still helping you steer.
Old Apr 20, 2010 | 01:49 AM
corvettedaddy11
i jus tried to turn mine on does the car hav to b on!!!!
Old Apr 20, 2010 | 01:51 AM
BigTattooMan
St. Jude Donor '10
Yes. At first it will say that the T/C is off (keep holding) then it will switch to comp mode have fun, be safe
Old Apr 20, 2010 | 01:52 AM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
Yes
corvettedaddy11
thanks for tha info guys!!!!
Old Apr 20, 2010 | 01:54 AM
BigTattooMan
St. Jude Donor '10
Hey man im right down tha road here in charlotte!!!!!!!!!!
Don't forget to wave and if you need anything hit me up
Edit: if you figure out Comp mode you may want to keep both hands on the wheel, I'd understand...
Old Apr 20, 2010 | 08:23 AM
Mike Mercury's Avatar
Mike Mercury
in order to have the Competitive Driving mode available.... your C5 must have the Active Handling system (not to be confused with Traction Control). C5's built from 1998 thru 2000... AH was an option (1997 C5's - AH wasn't available at all, Thanks for the correction Jack). Starting 2001, AH became standard.
Gen 1 AH (on C5's between 19987 and thru 2000) required you to be stopped to activate the mode. Gen 2 AH (on C5's from 2001 thru 2004) allowed the mode to be activated while moving.
For those with 1997 - 2000 C5; you must first determine if your car has the AH option. If it doesn't, then there's no Comp Driv mode.
I've found that it sometimes takes up to 10 seconds of button pushing for the mode to be enabled.
Old Apr 20, 2010 | 10:07 AM
Originally Posted by Mike Mercury
in order to have the Competitive Driving mode available.... your C5 must have the Active Handling system (not to be confused with Traction Control). C5's built from 1997 thru 2000... AH was an option. Starting 2001, AH became standard.
Gen 1 AH (on C5's between 1997 and thru 2000) required you to be stopped to activate the mode. Gen 2 AH (on C5's from 2001 thru 2004) allowed the mode to be activated while moving.
Unless you have the active handling option, you won't be able to activate the competition mode. Active handling was introduced mid-model year 1998 so not all cars will have it. It will say active handling above the traction control push button on the console. You can also look for option code JL4 on the option decal.
Old Apr 20, 2010 | 06:32 PM
vetteboy850
Mine does not say anything So i guess i cant enjoy it llike you guys.
Old Apr 20, 2010 | 08:02 PM
capehorn3's Avatar
capehorn3
I have a '97 so I don't have it available as an option? Can I do something to add it? I tried stopping, put in park, hold for 15 sec. no luck.
Old Apr 21, 2010 | 01:53 AM
herZ06's Avatar
herZ06
don't feel bad. my car has it, but it hates life... In other words, something is wrong with it and I really don't give enough of a crap to fix it. It will violently jerk the car the other direction trying to "fix" it from getting sideways, but it's no where near the smooth transition it's supposed to be. Then, it says "service active handling".
I'd rather just turn it all off anyway. That way, I'm prepared for when the car spins tires or gets sideways and I know how to react! Not, "oh, competetive driving mode is on, I'm good" then two seconds later be going "HOLY CRAP WTF was THAT????"
Old Apr 21, 2010 | 08:30 AM
Mike Mercury
No; as Jack mentioned above - the AH option wasn't available until mid production year 1998.
To Competitive mode.
Old May 2, 2010 | 10:03 PM
vetteboy850
Is their any way i can get it put in?
Old May 7, 2010 | 01:44 PM
vetteboy850
ttt
Old May 7, 2010 | 01:52 PM
dougbfresh's Avatar
dougbfresh
WHY?
