With my new tires, I went in for a wheel alignment last week to a place near by in Elgin, IL called Hartman Bee Line. They do lots of Vettes. I asked about the severe wear on the inside of the old front tires, the same seen on every C5 I had. He asked me if I ever drive competitively of which I answered, only general commuting. He said he can adjust the alignment differently than GM 1/4" negative camber on both tires.
He set the camber to 1/8" positive driver side, 1/4" negative passenger side. He said the car should handle fine for my driving, and though there will still be inside tire wear, it will be much less. I asked why so different, left to right? He said this compensates for the crown in roads.
I heard the same story when taking my motor home for a front wheel alignment, to a truck suspension shop....consideration for the crown in the road.
The Vette still handles just fine. If you are a commuter/joy rider with your Vette, this is worth consideration.
That is interesting, especially considering that I have 2 sets of tires & wheels that I use. One set run flats and one set not..Neither sets show any kind of inside tire wear and I don't have any offset alignment....
I'm showing inside wear on my tires (about 10kmiles on them) and I was talking to the "Corvette Guy" at the Chevy dealership and he said it was because of the aggressive camber as well.
Just replaced my run flats due to excessive front inside wear...I had the car aligned before I installed the last set because the set before those wore on the inside too.
I have also heard of setting at 0 camber for both.
I asked about a "Zero" camber. The shop said the tires sitting flat on the road will yield a floating/wandering handling problem, which made sense. With such wide tires, a sight offset camber would eliminate flat-floating action.
Every C5 Corvette I've turned (5 in all), the driver front tire sees the worst inside wear. The shop's consideration to the crown in the road and his setting of a positive 1/8 is a compensation that addresses the symptom.
The car handles just fine. It will be interesting to see how the front tires wear as the miles are racked up.
I could see this being a real bad idea if you compete with your Corvette. But for every day driving, this seems a good idea. Time will tell.
The shop said a fellow came in recently for his second vist. The first time was setting an extreme camber for a competition, then his return back to a "street use" setting.
I learned a lot that morning about this stuff.
