Hi guys, I have a problem..when I turn on my climate control, it blows heat on the drivers side at ant temperature it is set on...passenger side seems to blow cool when it is suppose to.. has this happen to anyone?
In the last week there have been about 4 threads on this. Go into your DIC and clear all HVAC codes and see if it resets. You should hear it cycle. Here's 2......
ok thx guys...looks like it's my left actuator...im getting a code 441..
Did you clear the code and see if it reset??? You should hear the system cycle then stop. Then start the car and see if the air is working on both sides.
Here's a link that will answer all your questions and teach you more about your HVAC Actuators than you cared to know. You can also do a search for 'B0441' to get some other threads related to your problem.
