LED Interior trunk lights
Old Apr 23, 2010 | 01:17 AM
goodref's Avatar
goodref
Cruising
Default LED Interior trunk lights
I want to replace the rear interior yrunk lights in a 2002 convertible. Do I pop the lens cover off, or pull the light/carpet back and replace the bulb from the rear? Thanks again for the help.
Old Apr 23, 2010 | 01:23 AM
DarkSpeed's Avatar
DarkSpeed
Just pull the lights casings out (gently to not break the side clamps) and pop-open the lenses,,,depends what style/design/size LED's youre using
You can get very creative on how you design those LED's, I have 24 LED panel lights in my trunk
Old Apr 23, 2010 | 09:17 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Pull the housing out. You'll see a small blue twist lock baseon the back. Remove this, swap out the 194 bulb for your LED bulb and re-install. (makee sure to check for correct polarity)
Old Apr 23, 2010 | 10:20 AM
tonylukes3's Avatar
tonylukes3
These are really easy to install, literally a 1-2 minute job.
Old Apr 23, 2010 | 12:18 PM
ICULUKN-C5's Avatar
ICULUKN-C5
I did mine... great cheap upgrade.
Old Apr 23, 2010 | 02:15 PM
cdnguyred88's Avatar
cdnguyred88
To LED Interior trunk lights
