Installed plugs and wires
Old Apr 24, 2010 | 08:47 PM
c5blkvetteguy's Avatar
c5blkvetteguy
Default Installed plugs and wires
I just got done with the install of plugs and wires. I went with the factory AC Delco plugs and red GM performance wires. Since I have a '97 I had to remove the rear alternator bracket to get at the front plug. That one was the only one I had an issue with. I did not remove anything else and found the job to be straight forward and fairly easy. The rear drivers plug is a little tricky, but not as bad as some people have made it out to be.
Old Apr 24, 2010 | 11:42 PM
Nice to do things yourself. I agree the change out is not too bad - just takes a little time is all.
Old Apr 25, 2010 | 12:07 AM
yaknow's Avatar
yaknow
I just replaced mine, no problems very straight forward especially while installing headers.
Old Apr 25, 2010 | 01:13 AM
dobewillie's Avatar
dobewillie
Good job now enjoy
Old Apr 25, 2010 | 01:21 AM
billymz28's Avatar
billymz28
It is to easy on a c5 I guess because I have no emissions and used to working on a fbody
Old Apr 25, 2010 | 08:17 AM
Jet-Jock's Avatar
Jet-Jock
This job is on my list of things to do. I have the AC Delco Iridium plugs and red performance wires. Now all I need is some time and a snap-on 5/8 double swivel socket.
Old Apr 25, 2010 | 09:03 AM
rws.1's Avatar
rws.1
Good choice.
Old Apr 25, 2010 | 11:27 AM
jrose7004's Avatar
jrose7004
You did good!
Old Apr 25, 2010 | 11:31 AM
dbaker's Avatar
dbaker
Lot's of good choices.
I like the NGK TR55 plugs and Taylor 79203 wires in my 02Z.
\db2
Carolina
Old Apr 25, 2010 | 11:48 AM
c5blkvetteguy
I did not use a swivel of any kind. Just a few different length extensions.
Old Apr 25, 2010 | 11:56 AM
McRCN's Avatar
McRCN
I just ordered plugs & wires for my '04 from Gene the other day. Any tips for an '04 would be appreciated.
Old Apr 25, 2010 | 02:18 PM
Jet-Jock's Avatar
Jet-Jock
As always with an aluminum engine, work on a cold engine. It's best to do them first thing in the morning after an overnight sit. Use silicone grease (dielectric) on the boots and anti-seize on the plugs. Torque your plugs. Proper torque keeps you from stripping and you achieve the designed contact for heat transfer.
The air pump hoses should to be removed to allow for easy access to #5, I believe, the few members who reported said it is easiest to just remove the two bolts and rotate the pipe out of position. This is discussed in the first link.
Here's a few good links:
http://forums.corvetteforum.com/c5-g...ark-plugs.html
http://forums.corvetteforum.com/c5-g...endations.html
I was informed that double swivel makes the job so much easier. I have two universal swivels but they tend to bind so I was going to invest in a nice quality plug socket with swivel. Now a real time consuming job is the plugs and wires on a LT1 in a C4. That required straddling the passenger from tire and slight contortion to get to #8. This C5 setup looks much easier.
Old Apr 25, 2010 | 04:28 PM
Turbopower87's Avatar
Turbopower87
I just did mine this afternoon and it was a little bit of a struggle and took a little longer than I thought since it was my first time ever doing plugs and wires on a car but now that I have done it I think it will be pretty easy next time. There are some good tips in the threads on here.
Old Apr 25, 2010 | 04:52 PM
88sk's Avatar
88sk
who else has the red wires besides culley?
Old Apr 25, 2010 | 05:17 PM
postwhore's Avatar
postwhore
use impact swivels
Old Apr 25, 2010 | 07:48 PM
Edmond's Avatar
Edmond
Parts Taxi has them as well, that's where I got mine from along with the Iridium plugs.
I can change plugs in my Z in about 40 minutes now.
I do have headers, though.
Old Apr 25, 2010 | 09:20 PM
TNX ZORA's Avatar
TNX ZORA
I found a surprisingly well made swivel 5/8 socket at Autozone. An expensive Snap-On version couldn't be much better.
To Installed plugs and wires
Old Apr 26, 2010 | 05:47 AM
csexton's Avatar
csexton
Good combo
Chuck
Old Apr 26, 2010 | 07:10 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I love it! Excellent
Thanks,Matt
Old May 19, 2010 | 08:24 PM
88sk's Avatar
88sk
just got my red wires today & put them on,my readings for all are 36 ohms ,but the MSD's I took off are 26 for 5 wires ,1 was 45,last 2 kept fluctuating between 100-200+ ohms,gonna try to send 3 back if I can
