Vararam Filter Removal - Need advice
Old Apr 26, 2010 | 01:26 PM
EZEDDIE's Avatar
EZEDDIE
Default Vararam Filter Removal - Need advice
Need to clean my filter and was wondering what clamps to remove to get to the filter. Obviously, I will start by releasing the rubber catches but I doubt there's enough play to remove the filter without undoing some clamps. Which one(s) should I remove? The one between the MAF and the filter? The one between the MAF and the air bridge or the one between the air bridge and the engine?
Thanks.!!!
Old Apr 27, 2010 | 04:53 PM
EZEDDIE's Avatar
EZEDDIE
ttt
I did a serach and didn't find anything definative.
Old Apr 27, 2010 | 06:42 PM
futuretech's Avatar
futuretech
I did the one after the airbridge. Seemed like the easiet way.
Old Apr 27, 2010 | 07:25 PM
Z06Electron's Avatar
Z06Electron
Piece of Cake!
Loosen the clamp on the throttle body. Undo the latches on the housing. Remove the entire top portion together as one unit. Clean filter and re-install. EASY!
Old Apr 28, 2010 | 01:04 AM
woofmaster's Avatar
woofmaster
Navigator
Default Filter type ?
I have a vararam with a K&N filter in my 02 that I bought last year. The fitting of the two vararam pieces with K&N don't seal tight. It has a foam ring that is supposed to fit to seal it and is needing replaced badly. I clean my very dirty filter often as it gets dirty quickly and kringe to think of the dirt that is slipping by into my engine. So, what type of filter and filter gasket should I use that will best keep my engine clean and perform well?
Old Apr 28, 2010 | 01:23 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I siliconed my filter into the upper housing after finding sand and a blade of grass in the accordion bellows. Don't trust the sealing of their foam gasket.
Old Apr 28, 2010 | 09:18 AM
54fighting's Avatar
54fighting
You may want to apply some 3M yellow adhesive to the seals just to be safe. The original glue dries up and fails over time.
Old Apr 29, 2010 | 02:46 PM
VaraRam Industries's Avatar
VaraRam Industries
Supporting Vendor
St. Jude Donor '07-'11-'12
The K&N will not fit the Vararam properly - was not made for it! You need to call us and get the proper filter!!!!
Steve
866-507-2648
Old Apr 30, 2010 | 01:42 AM
Z06Electron
Steve
866-507-2648
Steve will take great care of you. He and his product are amazing and I continue to buy and recommend his product because of it.
Old Apr 30, 2010 | 08:13 AM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
Old May 2, 2010 | 09:12 AM
woofmaster's Avatar
woofmaster
Navigator
Default Re: filter advise
Thanks guys for the great info...and Steve, I'll be giving you a call for getting a proper filter! I knew if there's ever a question about a vette, there's only one place to go. The advise and help everyone offers here turns most issues into small ones rather than bigger issues that can drive a person crazy, not to mention how much $$ saved to do it yourself and to learn about these awesome machines!
Old May 2, 2010 | 09:35 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
great company to work with.
To Vararam Filter Removal - Need advice
