Front rubber skirt needed?
Old Apr 27, 2010 | 01:12 PM
vettegator005's Avatar
vettegator005
Default Front rubber skirt needed?
So the front plastic/rubber that runs across the bottom of the front bumper is scraping on everything after i lowered my vette can i take it off or is there some important reason its there?
Old Apr 27, 2010 | 01:24 PM
76 VETTE's Avatar
76 VETTE
I think thats there to force air up accross the radiator.I really think you need it.
Old Apr 27, 2010 | 01:33 PM
goldwingerguy's Avatar
goldwingerguy
I'd like to know that also.....I just lost the right side one on the highway today and I think it looks better without it on.
80VetteStud's Avatar
80VetteStud
Its the front air dam, and it is needed from everything I have read. In fact I just bought the pieces new from Gene and reinstalled them so it would look better.
It helps push air up to cool off the radiator.
Old Apr 27, 2010 | 01:37 PM
hotwheels57's Avatar
hotwheels57
The front air dams scrape on most cars that haven't been lowered.
They're self leveling, so there's no reason to worry about it. If it really annoys you, some have simply cut off 1/4" to 1/2" of material off the bottom to reduce/eliminate the noise.
GM had a reason to use them, to direct air flow up into the radiator core.
vettegator005
how much did that run you?
Old Apr 27, 2010 | 01:38 PM
vettegator005
what did you use to cut it?
Old Apr 27, 2010 | 01:39 PM
dougbfresh's Avatar
dougbfresh
The front one is really needed, some have shaved off an inch or 2 after lowering. The 2 side ones are more for areodynamics than anything else.
Besides, nothing looks/sounds more AWESOME than a Corvette with what looks like a broken suspension dragging on every bump in the road.
Old Apr 27, 2010 | 01:40 PM
jrose7004's Avatar
jrose7004
It's self leveling so it shouldn't be a problem for long.
Old Apr 27, 2010 | 01:58 PM
hotwheels57
I didn't cut mine.
I'd rather hear the air damn scraping a little and remind myself to take a speed bump or curb slower than hear the chassis scraping and it's to late...
Old Apr 27, 2010 | 02:01 PM
Fast one's Avatar
Fast one
Mine self leveled to the road last year and is gone, temps didn't increase without it.
Old Apr 27, 2010 | 02:04 PM
80VetteStud
I believe they were 22.00 for one side and 18.00 for the other, my middle was still good. Just something happened to the sides. A new middle piece was like 84.00.
Gene has the exact pricing. And great to deal with.
Old Apr 27, 2010 | 03:13 PM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
I read somewhere that the outside dams are for keeping airflow from underneath the car at higher speeds, which results in slight downforce (as opposed to lift) and keeps the car (more) stable. At lower speeds you won't miss them. And, as mentioned several times, the center piece is for directing air into the radiator.
To Front rubber skirt needed?
