Thanks I will try that. I've seen those bolts with the rubber tops but I was afraid that If I raised them to high I might break the hood, because the lowest point of the hood is about 8" from those bolts. I will try it this evening with help and do it real slow.
I think those are anti rattle bump stops, you can only adjust the hood up/down with shims on the hinges I believe. I think the bar that the top of the front fascia attaches to also adjusts up/down to make the fascia fit the hood better but you have to remove the front fascia to get to it.
I studied it last night, but I was by myself. I've got all day tomorrow to play with it. The front of the hood lower than the cap. Thanks Guys, Iwill keep u informed
Yea the vararam jacks the hood up a tad since it hits on the underside no big deal the hood can be tweaked with the hinges and the rubber stop screws. I gotta do mine here soon
ive had similar problems after my cam install. i took the hood off to the the work. Now the front of the hood sits higher then the bumper... I think the Haltech killer bee 2 is the problem.
Should i take off the intake and see if it lines up?
