Normal oil pressure range
Old May 4, 2010 | 02:11 PM
raymondh's Avatar
raymondh
Default Normal oil pressure range
Anyone know what the normal oil pressure range should be for a c5 with about 86,000 miles. Thanks in advance.
Old May 4, 2010 | 03:07 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Mine is a 40K car with a lot of track miles. I run 10/30 oil M-!. When warmed up = temp above 150 deg. the car shows 35 LBS at idle and 40-44LBS or so above 2K RPM. Hope that helps.
Old May 4, 2010 | 03:41 PM
killain's Avatar
killain
Oldtimer
When cold, my 2003 with 13K miles starts at 50 PSI and once warmed up it is usually at 40 PSI at idle, and if in stop and go traffic and the air on and in gear A4, it is at 30 PSI. If I'm not wrong, you should have 10 PSI per 1000 RPM's.
Old May 5, 2010 | 07:57 AM
mickey_7106's Avatar
mickey_7106
40 psi cold and 30 psi warm (both at idle)
Old May 5, 2010 | 01:04 PM
That's about were mine reads.
Old May 6, 2010 | 06:54 AM
mickey_7106
43 psi at 65 mph 1850 RPM
Old May 6, 2010 | 09:16 AM
Oldvetter's Avatar
Oldvetter
Per shop manual, you only need 8 psi at idle.
Mine runs 25 psi idle hot (235 F) and 35-45 psi while driving with revs around 3,000 rpms.
The pressure bypass is set at 72 psi.
Old May 6, 2010 | 01:30 PM
SCM_Crash's Avatar
SCM_Crash
Cold mine reads about 45, warm it reads 40 (both at cruise). But my car has 20K miles.
Old Nov 6, 2021 | 06:36 PM
Robert200's Avatar
Robert200
1st Gear
Default I have a 1997 C5 46.000 miles oil sensor new reads 5 .
I changed my oil sensor now reads 4psi light to check gaguges is on. Disconnected wire pulled it out hooked up a manually gauge now reads 40 at start up cold 215 temp oil 30 psi 10% gain every 1000 rpm. Rev I get 65 or so . Can’t figure out what is going on I’m flustered
Old Nov 6, 2021 | 09:06 PM
vette4fl's Avatar
vette4fl
Old Nov 9, 2021 | 07:17 PM
smitty2919's Avatar
smitty2919
I've gone by at LEAST 10psi for every 1000rpm.
To Normal oil pressure range
