[Z06] foggy windshield?
Old May 6, 2010 | 08:40 AM
z06gaston's Avatar
z06gaston
Default foggy windshield?
Sometimes when it rains hard overnight. My windshield is a little fogged up?? I look inside and feel the carpet and every thing is dry?? Any ideas
Old May 6, 2010 | 10:46 AM
STIRitUP's Avatar
STIRitUP
I have that same problem. Not sure if you checked the trunk area, I noticed some light water back in the middle well there sometimes. Nothing major but slightly wet.
I would say even though you don't feel or see the water, it is definetely there hence the foggy windows. It is a common problem with the rubber weatherstripping going bad so no cause for alarm and you can replace it if you want a complete fix. For the summer my car was not garaged (I know the horror!) I bought a nice cover and never had a problem after that, so that can be a fix as well.
Old May 6, 2010 | 10:56 AM
z06gaston's Avatar
z06gaston
Yeah it's a headache... The weird thing the car was always garaged until now. The Z only has 34k and the weather strips look brand new all around. It's probably because our body panels are mainly fiberglass. Maybe I'll put some rainx anti fog on the shield and see if it helps.
Old May 6, 2010 | 06:02 PM
philadd's Avatar
philadd
You have water leaking in somewhere. I had the same problem until I tracked down all the leaks and sealed them.
There are many places where the sealant/glue used to attach the roof are not exactly "complete". Water leaks in, and goes places where you may not realize. After researching on here, I found a couple spots that were more obvious once I removed the interior. I had one spot that was not so easy to locate...
Unfortunately, the only effective way to track down your leaks is pull all the carpet out and have someone spray the car down heavily, while you look for any traces of water on the inside. The most elusive leak for me to find, was under the hardtop, just behind the doors. At that location, water drains forward and then down behind the doors somewhere. On the inside of the car, I found a very, very small area about 6-8 inches below and a little bit rearward of the upper seat belt mount. I literally could only stick one finger in there, but it was filled with water, which then overflowed and trickled back towards the trunk. Somewhere in there that was a gap in the sealant and water was leaking into the car. I used my finger and slowly filled that entire void with RTV sealant. I've been dry since. Of course, that's after sealing about 3 other leaky areas.
To foggy windshield?
