Which takes up less space?
Old May 9, 2010 | 03:34 PM
Ashc2025's Avatar
Ashc2025
Default Which takes up less space?
A subwoofer enclosure for the center storage space, or one for the two corners. I'm looking to do one of the two, if I use the corner space then it will most likely protrude out of the hole, but if I use the center it will be completely hidden. So, lose a side compartment and upper storage space, or lose the entire center space and keep the flush trunk and side compartments....
BTW I'm going to do this custom instead of purchase one by internet.
Old May 9, 2010 | 08:46 PM
HowlinC5's Avatar
HowlinC5
Go with the center. I put a high power (600 watt) 10 in my center and fit the amp in there. Looks awesome.
Old May 10, 2010 | 07:11 PM
Ashc2025's Avatar
Ashc2025
That was a plan I had, but I was goign to mount the sub vertically and hidden in a bandpass case, so I wouldn't have to worry about puncturing the cone.
Old May 10, 2010 | 10:38 PM
Turbopower87's Avatar
Turbopower87
I relocated my cd changer to the driver side compartment (along with a bag of tools), 10" sub in the center compartment, and my amp in the passenger side compartment. I couldn't ask for a better set up. Everything is completely hidden and it has the perfect amount of bump. AND I got everything (including the adaptor for the stock head unit, wires, etc.) for under $200. I spent a day of my spring break a couple years ago installing everything and I couldn't be happier.
Old May 10, 2010 | 11:52 PM
corvettedaddy11's Avatar
corvettedaddy11
JL 12W7
Old May 10, 2010 | 11:53 PM
corvettedaddy11
Old May 18, 2010 | 07:59 AM
Ashc2025's Avatar
Ashc2025
Originally Posted by corvettedaddy11
this is an awesome set up, I was hoping to make more space though, does that capacitor do well for both amps?
Old May 18, 2010 | 11:54 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
There really is no need for a capacitor at all, if your system is big enough to cause light dimming, do the big3 upgrade and be done with it. Other then for bling a capacitor is basically worthless
Old May 18, 2010 | 12:07 PM
corvettedaddy11
Yes helps a bunch bfore when tha bass hit interior and headlights dimmed bad an my volt gauge in dash dropped low but now it stays a little over 12v nothing dims now an when im in the garage with the radio on it doesnt kill my battery,So I thinks it worth it!!
To Which takes up less space?
