Killian take this cover from underneath of both sides with a 10mm socket wrench and youll see the foglight ,snake your hand up in bumper an you can feel the wires just twist an pull,EASY!!
Good luck!!
Good luck!!
Thank you, Where did you find the specs. for the foglights. I looked in the owners manual and it didn't list a replacement bulb ?Did you pick a regular 880 bulb or is there brighter bulbs out there ? I already replaced my upper and lower headlights with sylvania silverstars ? You have to drive at night to see the imporvment in lighting. For what they cost, I think their worth it !
