2004 Ground Clearance
Old May 12, 2010 | 01:41 AM
Jon Hekking's Avatar
Jon Hekking
Default 2004 Ground Clearance
My new 2004 coupe seems to have less ground clearance than the C3 or C4. What's the best way to protect the nose and air dams?
Old May 12, 2010 | 06:34 AM
You can get the little wheels that bolt onto the front of the radiator support bars. The air dams are pretty flexible and scraping pretty much comes with the territory - they are relatively inexpensive to replace.
Old May 12, 2010 | 12:25 PM
egrand333's Avatar
egrand333
Don't drive it. No matter how hard I try to be careful something always scrapes somewere.
Old May 12, 2010 | 12:54 PM
PostShawn's Avatar
PostShawn
FattDaddy for the front of the car and Rocker Skid Plates for the sides if needed.
Old May 12, 2010 | 01:01 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Tks Shawn
Peace
Chip
__________________
..................Click for
Old May 12, 2010 | 01:02 PM
paint-tech's Avatar
paint-tech
crawl under front and feel how flexable it is, unless you drive it like truck
you will be fine. I dont even use the rollers I still beleve they do more harm than good. If you incounter a ramp going to a parking lot Take out the steep angel by going at it at a angel not nose diving in.
Old May 12, 2010 | 02:03 PM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
Old May 12, 2010 | 02:42 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
personally, i don't like the "wheel" solution as you need to drill a hole through (side to side) the supports (probably weakening them a bit) to mount them and they can be seen under the car when looking at it head on from a bit back. they make a skid plate that can be mounted over the rails (on the bottoms) that absorb any scrapes and are as easily replaced and installed as the "wheels". the bottom line is that if you hit the front hard enough, nothing is really going to save you as you will probably bend or break the "axles" that mount the wheels and you'll destroy the skid plates and probably damage the rails also. both methods are designed to mitigate a mild bottoming neither will protect you against hitting the driveway exit a bit too hard, lol!
Old May 12, 2010 | 04:41 PM
34RedRage's Avatar
34RedRage
never thought much of the wheel solution, drilling a hole just weakens the support bar, and they look like crap from the front. reminds me of a pair of wheely bars insalled on the front...jmo!!!just drive with care and you will be fine....
Old May 13, 2010 | 01:00 AM
Jon Hekking
Thx everyone, much appreciated. The problem is I get used to where the C3 or C4 can go and I assume the C5 can go there as well. Sounds like I'm the problem
To 2004 Ground Clearance
