Serpentine belt
Old May 12, 2010 | 02:07 PM
markcvechko's Avatar
markcvechko
Default Serpentine belt
I replace the water pump 2 weeks ago and last night I threw the belt. It was brand new also. The auto store said that maybe the adjustment pulley was bad. I was pulling sohigh rpm when this occured. I ordered a new adjustment pulley assem. and a goodyear belt from summit racing. Hope this is the fix
Old May 12, 2010 | 02:20 PM
bigvx5's Avatar
bigvx5
did you check the tension on your belt after you put it back on?
Old May 12, 2010 | 02:32 PM
markcvechko
No how is this done
Old May 12, 2010 | 02:49 PM
lucky99's Avatar
lucky99
Belt tension is not adjustable you have a tensioner that is spring loaded. I would put old belt on start it up and watch the harmonic balancer. These car have a problem with the balancer seperating and causing belts to walk. Been there and it sucks.
Old May 12, 2010 | 07:40 PM
Goody's Avatar
Goody
If you installed the belt correctly following the guide sticker under the hood and if the tensioner is still good then something is wrong with the pulley alignment.......
Are you sure you got the correct Corvette waterpump? How do they compare size wise? (just a thought).
Old May 12, 2010 | 07:43 PM
ALLEGRO's Avatar
ALLEGRO
Check your tensioner to be sure it is not out of specs. There are marks on there to give you a basic idea, and there are diy threads here about more finite information.
Do also (as mentioned earlier) check your balancer. Could be a bigger problem than just a thrown belt.
Good Luck
Old May 12, 2010 | 08:23 PM
road dog's Avatar
road dog
That was my issue the balancer was bad and threw the belt . I had it replaced with a fliudapner from summit
Old May 12, 2010 | 09:09 PM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
I had thrown a belt once during a hard acceleration.
The belt was a fairly new Goodyear Gatorback.
I think there was an issue with the idler pulley as well.
I replaced the idler and installed Gates belts and have not had any trouble.
Best of luck.
Old May 12, 2010 | 09:18 PM
2EZ 2SPD's Avatar
2EZ 2SPD
Best of luck.
exact same thing for me
To Serpentine belt
