Headlight issues.
Old May 12, 2010 | 08:21 PM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
Default Headlight issues.
A few days ago my pop ups started to alternate. When the lights are off the driver light is up, and passenger light is down. When the lights are on, the driver's light goes down and the passenger light goes up. Even after I manually bring one of the lights they still keep alternating. What the hell is the issue.
Old May 12, 2010 | 08:32 PM
mtndv8's Avatar
mtndv8
Default Do both headlights come on when you turn them on?
Try this, disconnect the battery and count to ten, reconnect the battery.
I was working on my headlight wiring one day and only had one manually cranked up while the battery was disconnected. When I reconnected the battery to check my connections the manually up headlight bucket dropped as soon as I had enough threads screwed into the battery terminal to complete the circuit. Light switch was off. Lights operated normally before and after but I thought it might be worth trying for your issue.
