Best Air intake?
Old May 15, 2010 | 01:29 AM
EZ2BEVILC5's Avatar
EZ2BEVILC5
Default Best Air intake?
Hello,
I have read a lot of posts of Air Intakes, But I am still not quite getting a definative answer. It sounds like most people are getting about a
10HP increase from after market air filters. Some manufactures are posting ridiculous HP results. Are they all about the same? or air there any that are clearly better then others? I am interested in the BROTHERS because it comes with an aluminum tube which I like. I don't think the Vararam will work on mine because of my custom bumper. If there are some that are clearly better then others I will get that one.
Let me know.
Old May 15, 2010 | 01:54 AM
Jesse Asis's Avatar
Jesse Asis
Here is a quick rule of thumb, anything is better than stock, hp increases are there if you also work the exhaust so you can get a better flow, cat back, etc. I've only noticed my vette can get up and punch it better than stock. Prior on a stock air cleaner, it sounded like the vehicle had a hand over the intake, it was trying to get air to feed my demands. To really gain, you would have to get a Z06 cam to increase the duration the valves stay open to get all that extra air into the piston chamber. The engineers did a great job, you're just doing what they wanted to do but due to cost couldn't. Good luck....
Old May 15, 2010 | 03:03 AM
SCM_Crash's Avatar
SCM_Crash
I had the breathless performance vortex rammer... That was actually quite a good intake. I have the Vararam now which I love, but like you said, you have a custom bumper.
I'd try the Vortex Rammer. You have to cut the radiator shroud, but it really does work well and is dyno proven.
Old May 15, 2010 | 11:33 AM
34RedRage's Avatar
34RedRage
$50.00 from eBay, great set-up, filters great, (grease test approved) and looks great....
p.s dont forget the hood seal to keep water off the filters. i installed mine after the pics were taken!!
Old May 15, 2010 | 11:41 AM
jornahow's Avatar
jornahow
This is a topic that has been flogged to death:
I say the Callaway Honker is the best choice if you care about fit and finish as well as performance. Also has a CARB #
Old May 15, 2010 | 11:44 AM
socalman's Avatar
socalman
St. Jude Donor '10
Got a picture handy?
Old May 15, 2010 | 01:34 PM
jornahow's Avatar
jornahow
http://www.southerncarparts.com/corv...ke-p-2308.html
Old May 15, 2010 | 01:49 PM
Darion's Avatar
Darion
Callaway Honker on my car. Fit and finish were great.
I don't know if its the best, I think thats all about opinion, but it is a nice peice.
Darion
Old May 15, 2010 | 02:12 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
The best CAI is going to be whatever someone has on their car. They all have the same concept. Like someone said anything is better than stock. I use a aFe stgII CAI bigger filter and much bigger air bridge($200 ebay). The blackwing is also a good one. I dont like the idea of cutting stuff off my car to put a CAI on.
Old May 15, 2010 | 03:24 PM
hotwheels57's Avatar
hotwheels57
There is no definitive answer because "the best" (of anything) is different in everyone's subjective opinion. Keep in mind that others opinions might also depend on their budgets.
Make a choice. Like shifters, some people change their air intakes as often as their shifters...or underwear.
Old May 15, 2010 | 07:25 PM
Darion's Avatar
Darion
Thats true, I am on my third CAI. The next one will be made by A&A.
Darion
Old May 15, 2010 | 07:37 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Blackwing and others like that are not a CAI (cold air intake). They just suck HOT air from the engine compartment. Other words they are a air filter that breaths better. That is why I went with a Vararam it is a true CAI.
Old May 15, 2010 | 07:47 PM
jrose7004's Avatar
jrose7004
Just get a Blackwing and be done with it!
Old May 15, 2010 | 08:16 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
VRB2 and never look back! Worth 3/10ths in the 1/4 all by itself and no one else can say that!
Old May 15, 2010 | 09:43 PM
C54ever's Avatar
C54ever
Here's a pic of my aFe stageII.http://forums.corvetteforum.com/atta...1&d=1273978070
Old May 15, 2010 | 09:48 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
BPP Vortex.
/ thread.
Old May 15, 2010 | 10:39 PM
Luster's Avatar
Luster
Halltech...
Huge improvement in throttle response.
Easy installation.
No codes.
Looks clean and professional.
Reasonable price.
I wouldn't trade it for any intake on the market.
To Best Air intake?
Old May 15, 2010 | 10:47 PM
It is generally accepted that the Vararam will give the best power increase - but with a custom bumper, it may not work for you.
I have the Blackwing and like it - easy to install and no codes thrown. Have never had the car dyno'd though to tell what, if any increase in hp there was.
Old May 16, 2010 | 12:29 AM
EZ2BEVILC5's Avatar
EZ2BEVILC5
Default ?
Darion
I guess this is what I am after. Why are you on your 3rd. Is one a lot better then the other? was number 2 better then one and if so why buy a 3RD?
Old May 16, 2010 | 12:31 AM
EZ2BEVILC5's Avatar
EZ2BEVILC5
Default ?
You never had it dyno'ed but did you experience a noticable difference?
