Smokin
Old May 15, 2010 | 05:21 AM
redrager's Avatar
redrager
Default Smokin
I have a 98 corvettewith a smokin problem;when I really hit the gas hard it smokes.It is not oil smoke;and i recently had the air/fuel mixture set.Also I think I may have a leaky intake manifold gasket;there is a whistling noise coming from that area of the motor;maybe the two are connected?There is a aftermarket intake;mass air flow.any ideas?
Old May 15, 2010 | 11:09 AM
CurbsEnthusiasm's Avatar
CurbsEnthusiasm
Try cleaning her out with some Seafoam, worked for me on a Jeep and a friends Taurus.
Old May 15, 2010 | 11:13 AM
BOMDC5's Avatar
BOMDC5
Cruising
If not, then may have developed some valve damage. Probably not though with how well these motors are built, but you might want to run a compression check. Good luck.
To Smokin
