2000 corvette 6 speed overheats help????????
Old May 15, 2010 | 11:42 AM
blackfrc99's Avatar
blackfrc99
Default 2000 corvette 6 speed overheats help????????
delete
Old May 15, 2010 | 11:45 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
We need more info, Like what do you call over heating?
The LS1 in the Corvette does run on the hot side, It is very comon to see temps over 200 in the summer.
Old May 15, 2010 | 11:47 AM
blackfrc99's Avatar
blackfrc99
no my car after driving so much it goes all the way to like 275 285 and then i shut it off . have to let it sit for 30 mins or so then it it goes back to 220
Old May 15, 2010 | 11:58 AM
C5 4me's Avatar
C5 4me
could some trash be blocking radiator? Air in system?
Old May 15, 2010 | 12:07 PM
Daddyrama31's Avatar
Daddyrama31
Sounds like you may have some air in the system. Did you bleed the system properly after thermo and rad install?
Old May 15, 2010 | 12:11 PM
blackfrc99's Avatar
blackfrc99
you mean the radiator hoses or what do you mean ??
Old May 15, 2010 | 12:14 PM
Daddyrama31
Did you properly bleed your system when you replaced the thermo and rad? Did you run it with the rad cap off and let the system bleed out the bubbles?
Old May 15, 2010 | 12:16 PM
Mr.Bill's Avatar
Mr.Bill
Thats what I was thinking, I know when I first changed my T-Stat I took it for a drive and no time at all it was getting very hot. I had to burp the system and it has been fine since.
Make sure cap is in good shape.
Start w/ a cold engine
Remove rad. cap
Idle for 1 minute
Install cap
Cycle RPM from idle to 3000 until coolant reaches 210F
Shut off engine
Remove cap
Start engine
Idle for 1 minute
Install cap
Shut off engine
Remove cap
Top off
Old May 15, 2010 | 12:22 PM
Daddyrama31
Old May 15, 2010 | 06:55 PM
blackfrc99's Avatar
blackfrc99
it was fixed thanx guys
Old May 15, 2010 | 07:01 PM
Mr.Bill's Avatar
Mr.Bill
Well don't keep us hanging, What was it?
Old May 15, 2010 | 07:08 PM
blackfrc99's Avatar
blackfrc99
i only had blead the cooling system after i replaced the .....
thanx guys
Old May 15, 2010 | 09:35 PM
Daddyrama31
Glad I could help you.
To 2000 corvette 6 speed overheats help????????
