dash gauge rings fell off
Old May 15, 2010 | 05:35 PM
88sk's Avatar
88sk
Default dash gauge rings fell off
I need the instructions for takin the cluster off again,I shoulda used more glue on the rings,so far only the 2 smaller ones on the right fell off,aaarrrgh
Old May 15, 2010 | 05:41 PM
jdmvette's Avatar
jdmvette
Night Owl for life
paint them this time. guranteed to not fall off.
http://forums.corvetteforum.com/c5-g...zels-pics.html
WildWolf's Avatar
WildWolf
this happened to me a few years after I installed them. I believe it was going from the severe cold to the hot summer months that caused them to fall off. good luck
Old May 16, 2010 | 12:34 AM
Check the Vette Essentials web site. Should have some instructions there that will help you out.
Old May 16, 2010 | 01:32 AM
ALLEGRO's Avatar
ALLEGRO
Here is the instruction set I used. Step-by-step with lots of great pictures. There are even some good suggestions about using seperate bags for different area's screws, nuts and bolts.
http://www.vetteessentials.com/instr...zel_howto.html
I have taken ming off several times (for several reasons) and you should be able to get it off or on in about 15 minutes. Add to that the time to clean and re-attatch, you are in and out in less than an hour with no issues at all.
Good Luck
Old May 16, 2010 | 11:04 AM
Mike Mercury's Avatar
Mike Mercury
That is a major part of why rings come off years-after installation.
The thick CA glue does a good initial job of adhering everything... but cures rock-hard. There's no "give" left to handle expansion & contraction via temperature swings.
This is worse on the speedo & tack rings. I had to redo one of mine - and I used clear RTV silicone this time. It adheres great, and does allow the ring to move a little without fear of breaking the bond. The drawback is that you'd need to let the cluster sit overnight before reinstallation; as the RTV doesn't cure as quickly as CA glue.
Old May 16, 2010 | 11:11 AM
Z06Electron's Avatar
Z06Electron
Mine were installed with 3m adhesive body tape and have been in my Z06 problem free for over 4 years now.
To dash gauge rings fell off
