rich
Old May 16, 2010 | 09:13 PM
rich goepfrich's Avatar
rich goepfrich
Default rich
help, I need to get to my driverside window.How does the door panel come off? I can't find the info anywhere here in the forum..Thanks
Old May 16, 2010 | 09:18 PM
GreenDream's Avatar
GreenDream
It's on here.. Just search for Window adjustment or Window tilt. Did you try door panel removal. I printed it off but don't remember the exact search.
Old May 16, 2010 | 09:19 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
you will need to pop off the little plate behind the door pull first and remove the 2 screws
The panel just snaps on...you need to be careful not to break the tabs but you should be able to grab and pull..steady pressure...a removal tool would be best but you can do it by hand just be careful...start on the lower back corner you will feel where the tabs are
To rich
