It's pretty easy actually. First remove the little plastic clip under the grab handle to expose screws, remove. Then get one of those door panel removal tools (cheap), run it inside the slight gap between the door panel & actual door (careful not to scratch the paint). The plastic clips have a ratcheting-type design and should pop out when you pry back with the tool. Follow around the entire door until the panel is separated from the door, then lift up and away from the door. That should do it
HI There Rich,
I think this is exactly what you are looking for. www.youtube.com/watch?V=Xm1Xu-fvZxo This video shows how easy it is to remove the panel.( Called install corvette regulator in case you need to do a google search) Or you could go to this web upand downmainstreet.com.
robsc501
HI There Rich,
I think this is exactly what you are looking for. www.youtube.com/watch?V=Xm1Xu-fvZxo This video shows how easy it is to remove the panel.Or you could go to this web upand downmainstreet.com.
robsc501
Easy, as stated above. Remove the snap-in piece under the door pull. remove the two screws. I just used a flat head screw driver and placed it in the middle of back door panel and gently pull out. then use your hands to pull the rest out.It will all pop off, then lift up and off. Takes about 5 minutes or less.
but you forgot about the door handle pull surround. That has to come off too and it just pulls off with your hand and a flat head screwdriver
