[Z06] How Do U Get It To Look So Good?
How do you do it? I read about something called a "Clay Bar" but I also read cautions about using them.
So, I ask, what are y'all using to make your 'Vette REALLY stand out? Mine looks good but not like some!
Thanx,
Tom
GR8KAR
Personally, as a spray pianter for nearly 30 years, I am a 3M Perfect-It guy from the bottom up. Finished off with a quality carnuba wax.
But I have to admit, I use Zymol in between all out detailing. I am going to consider the ground up Zymol process in the future. I even use the Zymol on my carbon fiber Madone road bike (bicycle) people like to touch that too.
And finally, don't be afraid of damaging your paint with the PC... the "DA" action helps prevent heat buildup, so as long as you keep it moving, you should be fine... Be warned though: once you get get started at this, you're going to get reaaaaaalllly **** about keeping it clean.
Thanx,
Tom
GR8KAR
I think it is important to know that many of these products have a system. Various chemicals at different steps, then wax. In my many years of spray painting, more times than not, sticking with a porduct line reduced 'clouding' even in a marginal degree. When I say marginal, its like when you know "mom didn't make that pot of soup" close, but not "moms".
It is true that I have been out of the painting game now for a number of years and technolgies have changed. But from a painters perspective, I do appreciate the 3M line for its degree delight, but also from the stand point of a fender bender. I wrestled years ago with things like teflon coating while trying to "repair" a car. There were times were I couldn't get that stuff out of the finish to be repaired, which would have compromised the integrity of the repaired finish. I was always comfortable with 3M and their "system" beacuse it was painter friendly.
The inserted pic's are from years gone by... Before the digital age... The reflection in the black 944 was after I painted the car. Beyond my friend in the pic is the reflection 2.5 blocks away.
I guess in a nut shell, beyond clay bar, I simply encourage a system with in a product line. I think you will be happy. Me I think "system" for compatability, glamour.
Back in the day, I used to rub the finished vehicle down with Happich semi-chrome. You could not get a towel to stay on the car.
Think system is my humble opinion for clarity.
Thanx,
Tom
GR8KAR
If you use multiple products ie. Cleaner, Polish, Wax.
In my own opinion, use seperate towels (micro fiber) for each chemical.
Cross linking contamination can produce clouding, and a rag that just 'feels' nasty on a car.
Think green? I don't know, but think CLEAN.
(same with applicators too - one chemical - one applicator)
Zaino Z5 (Mixed with Zaino ZFX) - Let dry and remove
Zaino Z8 - Wipe car to ensure all polish is removed
Zaino CS - Let sit on car and dry over night
Zaino Z8 - Wipe car to dust off from garage dust.
Sit back and be amazed.....
I find that the shine gets deeper every time I use it. I hear that DAWN or any other type of dish soap will remove all polish. I would try not to use dish soap at all. Let the polish build up on the paint.
It works for me....
I have come to believe, like mentioned above, the process and tools are more important than the products used.
Wash, clay bar, polish, wax.......
Use the proper product (polish & pad, clean microfiber towels) in the right order (ie- swirl remover, then fine polish, then wax). Your car will look great!
I have been detailing my own car with Adam's polishes and a random-orbital polisher for years. It has looked fantastic each time!
I recently took it to a professional who uses a rotary polisher (I don't have the skill or guts to use a rotary) and he made it look incredible!!!
Once you have it looking good, the less you touch the finish, the longer it will last.......!
Good luck...
I wonder how many times I have counted to 4 with the rotary. 1-2-3-4 over and over and over.
You even mentioned towels. Yes, the micro fibers do have there place, but I still love buying the 10 pound bag of used/laundered diapers from the diaper service company. Good enough for a babies bottom, good enough for anything on wheels.
I had to take the time to say nice pics! That red is tough to take pics of! Those exposures are dead on! I like the depth of field setting in the pic with the white house. I have a cheesy digital, but a whole lot of dough wrapped up in medium format gear. Again, those exposures are great.Zaino Z5 (Mixed with Zaino ZFX) - Let dry and remove
It works for me....
Here is mine.
